Old 06-30-2011, 09:05 PM   #1 (permalink)
Diesels the best way to get high MPG?
Super high MPG cars we may never see - GasSavers.org - Helping You Save at the Pump Hypermiling and Fuel Efficiency Forum
There are a few cool cars in there. A lot of them are diesel/turbodiesel. Is diesel the best way to get high MPG? Is that because of the efficiency of the much higher compression ratio?
Old 06-30-2011, 09:42 PM   #2 (permalink)
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Accord EX
HvyDrnkr - '93 Seville
Yes, yes, yes! At least for right now. If you look at the new gasoline/direct injected engines, it's all diesel technology using a different fuel and a spark. Mazda's Sky Activ ( gas version ) uses 14 to 1 compression, direct injection and other jiggery pokery to do the deed.
Part of it is the high compression ratio, the other part is the energy density of the fuel. Diesel fuel has more energy per gallon than gasoline. The cam timing usually trends toward making maximum torque at low engine speeds, so you don't have to rev it as high.
So the combination of all these elements yields a high mpg device.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
Old 06-30-2011, 11:59 PM   #3 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Plus they're not throttled.
Old 07-04-2011, 02:15 PM   #4 (permalink)
I have to start over?
Big inefficient truck - '94 Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Civic DX Hatchback
The downside is that usually a diesel engine that has the same "right foot power" (not rated horsepower, but equal driveability) will probably be heavier than a gas engine. But I think most people can overlook that.
Old 07-06-2011, 01:11 PM   #5 (permalink)
I really like my new TDI Golf, but your driving conditions will dictate your optimum drivetrain. Unfortunately, it doesn't do anywhere near as well in stop-and-go city traffic as hybrids do. I do mostly highway miles, so it's the right tradeoff for me (especially if I can kill the karman vortex street somehow; I'm working on building up enough 70mph mpg data so I can tell whether airtabs make a difference).
Old 07-06-2011, 03:30 PM   #6 (permalink)
DieselMiser
ConnClark's Avatar
Das Schlepper Frog - '85 300SD
90 day: 23.23 mpg (US)
Diesels also have an inherent advantage in the constant pressure expansion of the power stroke in the diesel cycle. You get more work out of the same fuel energy than you do in the Otto cycle all other things the same.
Old 07-06-2011, 03:44 PM   #7 (permalink)
Diesel_Dave's Avatar
White Whale - '07 Ram 2500 ST Quad Cab 2wd, short bed
90 day: 33.32 mpg (US)
I agree with pretty much everything that's been said. The biggest factor is the cycle/compression ratio. Throttling is big too. Just to add a few things.
Diesels (typically) run at slower rpms as well, so there's less friction. Also, most modern diesels are turbocharged so it allows for the recovery of some of the exhaust heat.
Diesel Dave
~Life is an optimization problem.~
~Who says that just because your vehicle weighs over 3 tons that you can't get good mileage?~
Old 07-06-2011, 05:45 PM   #8 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
I'm not so sure diesels have less friction. In spite of turning lower rpms, they typically have longer strokes; interestingly enough there are many gassers that run 1000-1200 ft/mn piston speed while the two stroke diesels anyway are running 1700! The ring pack is the largest single contributer to friction so higher piston speeds must lead to higher friction.
Plus they have heavier rotating/reciprocating parts which add friction.
Old 07-06-2011, 06:36 PM   #9 (permalink)
57.4 mpg best trip.
Mercedes 89 D - '89 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Octavia TDI PD
90 day: 41.14 mpg (US)
Send a message via Skype™ to oldbeaver
Comparison of Diesel and Petrol engines (yield)
According to Wikipedia
Engine efficiency - Wikipedia, the free encyclopedia
thermal efficiency of a modern petrol engines is about 18 to 20%, meaning they convert 20% of total heat of petrol combustion into movement.
On the other hand, diesel engines have a thermal yield of about 40% .
From the best of my knowledge, the main reason isnīt for rpm or friction or even the fuel energy(but they count also), but for the thermodynamics curve of the diesel cycle. It works at higher pressure that needs a fuel that do not detonate at that high pressure.
Turbos are allowing constructors to make smaller and lighter engines with a lot more power, while other advances are allowing them to supress noise and vibration a lot.
It is common to see Jeeps with diesel engines that used to had 2500 cc that turned to 2200 cc producing more HP than their predecessors.
OldBeaver
Skoda Octavia 1.9 TDI
Old 07-06-2011, 07:15 PM   #10 (permalink)
low&slow's Avatar
l&s' Jag - '00 S-Type SE
90 day: 26.32 mpg (US)
l&s' Vision - '82 Vision XZ550RJ
90 day: 63.28 mpg (US)
L&S' Ninja 250 - '99 Ninja EX250F Ninja 250R
90 day: 86.13 mpg (US)
The diesel motorcycles in the 2011 Vetter Challenge got better fuel economy than the gasoline bikes despite having much bigger engines. The top 3 diesel bikes got 128mpg , 110 and 90 respectively while the best gas bike ( 250 NiNja ) got 94 mpg. Diesel has a lot of advantages as stated above over gasoline engines.
