Old 12-07-2010, 02:54 PM   #1 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 Golf
90 day: 51.68 mpg (US)
Diesels and EGR
I have been reading up on EGR and mpg and it seems to help in gasoline engines. It makes the engine act like a smaller engine and reduces pumping losses. There is less vacuum working against the throttle plate so the engine is more efficient at part throttle. A diesel doesn't have a conventional throttle plate so does EGR help mpg or efficiency on a diesel??
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
Old 12-07-2010, 03:17 PM   #2 (permalink)
Custom User Title
Nut Wagon - '91 Civic Wagon DX
90 day: 52.46 mpg (US)
I know two people with TDIs. One of them disabled the EGR. He hasn't had any change in mileage that I'm aware of. I get paid to clean out the other guy's intake manifold. It's not hard to temporarily disable the EGR to test the MPG difference. But you will increase the NOx emissions and get a check engine light.
Driving a 1991 Honda Civic Wagon and building a 1994 Geo Metro XFi.
Best tank with the Honda so far is 61.65 MPG.
Old 12-07-2010, 04:09 PM   #3 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 Golf
Thanks Gas Fumes, Do you still have to clean the intake manifold since low sulpher diesel? My car is a 2004 PD with the O2 sensor. I have been told that my car won't run very well with EGR blocked unless I reprogram the computer.
TDi=fast frugal fun
Old 12-07-2010, 05:14 PM   #4 (permalink)
UFO
UFO's Avatar
Beetle - '01 Beetle GLS
90 day: 42.61 mpg (US)
4x4 - '89 Pickup DLX
90 day: 30.36 mpg (US)
When I ran with disabled EGR in my TDI (with CEL set) it made no significant difference in economy. However it made a huge improvement (about 10%!) in the fuel economy of my Jeep CRD, and that has a modification that tricks the ECU so it doesn't set a CEL.
So I am working on the same device for my TDI and will document any differences here when I do that.
"We think B20 is for suckers" N. Cowell, Denver B100
"Climate change denial is a conclusion in search of a rationalization" labman57
Old 12-07-2010, 06:17 PM   #5 (permalink)
Big Dave's Avatar
The Red Baron - '00 F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Impala SS
90 day: 21.03 mpg (US)
It varies from engine to engine.
Doesn't seem to help VW TDI engines.
It helps Ford 6.0 and 6.4 engines a lot as it does the Cummins 24 valve.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Hard Tonneau and Rugged Air Dam
Old 12-07-2010, 11:11 PM   #6 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Legacy Wagon 2.5 GT
Last 3: 23.78 mpg (US)
Maus - '94 Civic VX
90 day: 54.33 mpg (US)
Helga - '00 Jetta TDI
90 day: 57.68 mpg (US)
Originally Posted by Gasoline Fumes View Post
... But you will increase the NOx emissions and get a check engine light.
My understanding is that you will bump the NOx emissions quite a bit if disabling the EGR on the diesel ... cat can't handle the higher NOx emissions (whereas it can handle the other emissions much better) ... and the NOx is the nasty of the possible emissions (responsible for acid rain, ozone (smog) creation, health probs, etc etc).
Old 12-08-2010, 12:19 AM   #7 (permalink)
UFO
UFO's Avatar
The catalytic converter on most diesels is an oxidation catalyst and is not designed to deal with NOx. Disabling the EGR will have no effect on the cat.
Old 12-08-2010, 12:53 AM   #8 (permalink)
NightKnight
Maus - '94 Civic VX
Ah, OK... so then the higher NOx emissions would just pass right through into the atmosphere?
Old 12-08-2010, 07:19 AM   #9 (permalink)
Custom User Title
It wasn't long ago that I cleaned it and he had it cleaned by somebody else a couple of years before that. He's running WVO most of the time too. Still gets clogged with a black sooty tar. It's a 1999.5 TDI. The other one with the EGR disabled is a 2002 TDI running on diesel only.
Old 12-08-2010, 09:02 AM   #10 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
They put cats on diesels now?
What next, spraying pee pee into the exhaust?
On a TDI I believe you can reprogram the computer to use the EGR when cold but close it off when warmed up. Seems Fred's TDI Page. TDIClub.com. VW TDI Enthusiast Community had a tutorial on this. TDI FAQ
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Cooled EGR Piwoslaw EcoModding Central 50 03-16-2011 03:40 PM
Theory: not just disabled cylinders, but a power/compound cylinder engine mechman600 EcoModding Central 18 04-16-2010 07:02 PM
How do you eco-drive a diesel ? groar Hypermiling / EcoDriver's Ed 105 04-03-2010 08:25 PM
EGR dilution for more MPG? cfg83 EcoModding Central 18 04-29-2008 09:11 PM
News: Only 6% of Americans think diesel will succeed as powertrain option MetroMPG General Efficiency Discussion 38 02-14-2008 02:23 AM
