Old 10-24-2008, 08:55 PM   #21 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
FastPlastic -
Originally Posted by FastPlastic View Post
Could you use two sheets of magnetic material connected together with some sort of fabric? Making a hinge of sorts? Like the stuff they make cloth tops out of?
I think so, as long as you got the details right. By details I mean how much expansion there is when the hatch opens. You'd have to fiddle with it after it is in place. Maybe a rubber/plastic of the right mil thickness, like pond liners and such. I have some I could use from a defunct roof-pond experiment back in the day.
But I'm just all talk right now, I haven't built anything.
CarloSW2
American Solar Energy Society
Old 10-26-2008, 08:49 PM   #22 (permalink)
Tracy - '00 corsa
i cut and heat bended my kammback yesterday. i still need to do the attachment bracket for the top hatch hinge. i have decided on making that seperatly and bolting + gluing the bracket to the kammback. apart from being supported from the top it will just be held down with tape at the sides etc.
things i learnt when making it was that the plexiglas snaps clean in one movement, so don't plan any complex curves or corners. also be careful with cutting the scoring. one wrong move can lead the break in the wrong direction. heat bending was easy but i didn't do as nice a job as tomo.
i was trying to work out which way the areo forces will act on this thing. if there is low pressure under the kammback and laminar flow over it, then hopefully the force would keep it in place?
i plan to make it removable - an assessory for when i do serious motorway miles.
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 10-27-2008, 05:39 PM   #23 (permalink)
Tracy - '00 corsa
how do cycle carriers attach?
Old 10-27-2008, 06:21 PM   #24 (permalink)
Tracy - '00 corsa
today i tried to make a plexiglas attachment strip that would wedge under the hatch hinge and hold the kamm. it didn't work. the long strip was too big and bulky to fit under the hatch hinge.
instead i have been looking at picture frame mounting hooks.
i will bend strips of steel to form a hook at one end, like the picture fame mounting hooks. this will hook under the hatch hinge and the other end will bolt onto the kamm. for support i will mainly hang the kamm from the top hatch hinge but i will also have a couple of hooks at the sides preventing lateral movement.
Old 11-22-2008, 04:51 PM   #25 (permalink)
Efficiency freak
Bearleener's Avatar
Frugolf - '96 Golf wagon
90 day: 40.36 mpg (US)
Have any of you guys done a quick-and-dirty test of how much a kammback might help simply by leaving the hatch about half open, maybe filling the sides with cardboard? (And somehow preventing exhaust from getting sucked into the interior?)
You ever notice that birds pulse & glide, too?
Project: making a permanent Metro Kammback extension MetroMPG Aerodynamics 251 12-02-2011 01:24 AM
Vibe Kammback / Boat tail trikkonceptz Aerodynamics 7 05-30-2008 11:23 PM
Kammback design trikkonceptz Aerodynamics 1 05-07-2008 06:07 PM
