Old 07-11-2010, 04:10 PM   #1 (permalink)
differential pressure gage
Series 2000
Magnehelic® Differential Pressure Gage
I've had one of these sitting around in the garage for a few years and wonder if anyone on the forum could suggest a use for it in evaluating possible aero mods to my Solectria Force. (97 Geo metro 4 door body)
My thoughts are that it would be educational in determining the pressure difference between various locations on the vehicle at different speeds and after and before mods.
Any recommendations or insight would be appreciated.
I didn't find any threads doing a couple of simple searches.
Thanks
Old 07-11-2010, 05:00 PM   #2 (permalink)
You can do lots with that Magnehelic. Look at the following:
Magnehelic projects
The Following User Says Thank You to RuHaSs For This Useful Post:
EVDRVR (07-11-2010)
Old 07-13-2010, 05:46 PM   #3 (permalink)
book
Originally Posted by EVDRVR View Post
Series 2000
Thanks
If you can come up with a copy of Paul von Valkenburg's " RACE CAR ENGINEERING it will show you a bunch of things you can use the MAG for.
They can also be used as an airspeed indicator ( 1-3-inches is a good scale ).You'll have to re-face the dial.
Dwyer makes some nice pitot tubes and they also make a wind-seeking head which will allow for relative winds ( important with vehicles ) which a fixed pitot would not.
Proposed braking test: comparing tire pressure @ 50 psi vs 35 brucepick EcoModding Central 55 06-11-2011 08:29 PM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
"Inflation pressure does not affect grip": Autospeed article. orange4boy EcoModding Central 158 05-06-2010 03:29 PM
Need report refs for tire pressure benefits Ernie Rogers EcoModding Central 7 04-20-2010 01:31 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
