Old 03-11-2008, 07:08 PM   #11 (permalink)
Oden - '00 Frontier Crew Cab
Pickups
90 day: 21.99 mpg (US)
Malinda(WJ) - '03 Grand Cherokee Limited
90 day: 15.28 mpg (US)
Nerdcycle - '81 CM400E
Motorcycle
90 day: 53.8 mpg (US)
Bumblebee - '08 V3
Motorcycle
90 day: 69.17 mpg (US)
Protocol
Originally Posted by cfg83 View Post
extragoode -
I have one but I haven't got it to work consistently. But, it may just be a function of the car it interfaces to. It was fickle for my Saturn.
Also, all the good Software costs extra $$. The free software doesn't have good downloading capability (that I have found).
It's main virtue to me was that it shows the 02 sensor(s) and short/long term fuel trim, which the SG does not (boooo!). I got discouraged so I put it on my back burner list.
CarloSW2
Do you know which protocol your Saturn uses? The compatibility chart linked to on there site says my nissan uses an ISO 9141-2 or something like that. I'm going to do some more research before I believe them, but wouldn't be suprised if it works somewhat differently with different protocols. Does that make sense?
Old 03-11-2008, 07:21 PM   #12 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
It makes a lot of sense. Also, it might be something to do with my PC configuration. I have this one (the one for GM products) :
ElmScan VPW Scan Tool - P/N: 420300
http://www.scantool.net/products/pro...products_id=12
The ElmScan VPW Scan Tool comes mounted in a steel enclosure and can be used with our free software to turn your computer into a sophisticated auto diagnostic system. This interface supports the J1850 VPW protocol used mostly in General Motors vehicles.
I suspect that because I am a Saturn, I am a little different from the protocol POV. But, since the ScanGauge "just works", I was expecting the Elmscan to "just work" also, so I was miffed.
If I had the time (doctor, if he has the time), I would dig into it and write my own customized datalogging interface.
CarloSW2
American Solar Energy Society
Old 03-24-2008, 04:25 PM   #13 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
Re: Saturn
I'm thinking the freeduino has enough processing power to be a mpg gauge AND fix some of the ailments that saturn hypermilers suffer, i.e. give you cruise control back after a 5th gear swap, and do a better job of managing the idle speed. Maybe it can correct a speedo after putting different sized tires on too
Well, vehicle specific versions of opengauge isn't at the top of the list currently, but the project is now open to donations
http://sourceforge.net/project/proje...roup_id=222201
Old 03-24-2008, 08:48 PM   #14 (permalink)
Insert Clever Title Here
humanoid's Avatar
Taco - '99 Tacoma PreRunner
90 day: 20.19 mpg (US)
Pilot - '05 Pilot EX-L
90 day: 18.08 mpg (US)
Have you looked into the ScanGauge yet? I'm running a group buy on it on several forums.
Free mpg gauge...sort of tasdrouille DIY / How-to 7 01-11-2009 08:55 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 04:57 PM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 10:04 PM
Scan Gauge: Help ME!!!! bennelson EcoModding Central 6 02-08-2008 07:16 PM
