Old 03-07-2008, 08:26 PM   #1 (permalink)
Oden - '00 Frontier Crew Cab
Pickups
90 day: 21.99 mpg (US)
Malinda(WJ) - '03 Grand Cherokee Limited
90 day: 15.28 mpg (US)
Nerdcycle - '81 CM400E
Motorcycle
90 day: 53.8 mpg (US)
Bumblebee - '08 V3
Motorcycle
90 day: 69.17 mpg (US)
Digital Gauge suggestions
I would ulitmately like to put digital gauges in my vehicle. I love the functionality of the scan gauge, but I can't find any information anywhere as to whether it supports realtime output. If not, what's the best alternative to the SG that does support it?
Old 03-07-2008, 09:45 PM   #2 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
What do you mean by realtime output? If you mean can you capture data from it on another device (palm, laptop), no. But the digital info available on it is live (eg. all the gauges, instant & avg fuel consumption, etc.)
Old 03-07-2008, 09:54 PM   #3 (permalink)
MP$
diesel_john's Avatar
Send a message via MSN to diesel_john
Smile
the only real time signals are signals in the time domain, not sure what parameter you want to look at? digital displays by their very nature have some averaging built in or the human eye could not see them. if your testing at steady state conditions, a reasonable delay might actually be beneficial, e.g. when the dispaly stops changing, take your data point. tell us what you want to do.
Old 03-07-2008, 10:06 PM   #4 (permalink)
Who
UnderModded
Pablo - '07 Santa Fe AWD
90 day: 23.62 mpg (US)
http://racergadget.com/category/gauges/
Old 03-08-2008, 12:07 PM   #5 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I think the SG will work for you!
By the way, welcome to the site!
Old 03-08-2008, 07:02 PM   #6 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
extragoode -
Welcome to EM! What's your price point? The SG is around $150.
If you want to go hardcore, then I would do a lot of research into a tuner gizmo like this :
Apexi AFC NEO-FUEL "Piggy-Back" Color Display Air Flow Converter Computer - $370
http://www.2kracing.com/product_info...b83c867b5463c3
- Compact "Piggy-Back" Fuel Management Computer (+50% ~ -50%). - Unit incorporates both the SAFC and the VAFC. - NEW "Easy" (8-Point) & "Pro" (16 Point) Modes. - NEW Color FED Display & Interchangeable Button and Background Colors. - Inverting "anti-glare" screen allowing view from both angles. Monitor Mode: - RPM, Throttle, Battery Voltage, Correction %, Air Flow %, Pressure (Kpa), Karmann, VTEC Setting Mode: Air Map, Air Map Graph, Throttle Point, Deceleration Air, VTEC Control, VTEC Unmatch Etc. Mode: MOdel Select, Mode Select, Sensor Select, Analog Select, Warning Set, Display Set, Sensor Check
Hrmmmmm, I don't see MPG in the list above, maybe not so good, .
It's also a lot of upfront cost and that's NOT including installation, which would be more than the super simple "plug it in" ScanGauge. But, I think it could end up giving you more flexibility in the long run.
CarloSW2
American Solar Energy Society
Old 03-11-2008, 04:35 PM   #7 (permalink)
Pickups
Motorcycle
Bumblebee - '08 V3
Motorcycle
What I want is something like the dashdaq that was mentioned on the page Who linked to. I like the data that the scan gauge provides, but I want a realtime (or near it, I understand that realtime would update way too fast) data stream to an external computer which could be used to display and analyze the data. As I understand the scan gauge's only interface to a computer is to disconnect it from the obd2 port and plug it into a computer to download a batch of data. Basically, what I'm looking for is the cheapest/best/easiest way to interface the ecu to a computer plus any recommendations or advice from anyone who has already done this.
Old 03-11-2008, 05:02 PM   #8 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Sounds like this is what your asking for.
http://www.scantool.net/
Old 03-11-2008, 05:11 PM   #9 (permalink)
Pickups
Motorcycle
Bumblebee - '08 V3
Motorcycle
Bingo!
That's almost exactly what I'm looking for! Actually now that you point that out, it looks and sounds very familiar. I think found it a couple years ago and forgot all about it. It's even compatible with windows AND linux. Does anybody have any experience with these?
Old 03-11-2008, 06:22 PM   #10 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
extragoode -
I have one but I haven't got it to work consistently. But, it may just be a function of the car it interfaces to. It was fickle for my Saturn.
Also, all the good Software costs extra $$. The free software doesn't have good downloading capability (that I have found).
It's main virtue to me was that it shows the 02 sensor(s) and short/long term fuel trim, which the SG does not (boooo!). I got discouraged so I put it on my back burner list.
CarloSW2
Free mpg gauge...sort of tasdrouille DIY / How-to 7 01-11-2009 08:55 PM
All New Nissan Models to Feature Fuel Efficiency Gauge MetroMPG General Efficiency Discussion 6 11-18-2008 04:57 PM
Will Scan Gauge work on mine? bennelson Instrumentation 9 02-19-2008 10:04 PM
Scan Gauge: Help ME!!!! bennelson EcoModding Central 6 02-08-2008 07:16 PM
