Old 04-14-2010, 09:28 PM   #1 (permalink)
Hypermiler
brucepick's Avatar
Lean Burn Civic - '97 Civic HX
90 day: 51.96 mpg (US)
Disconnecting MPGuino to reroute wires?
Just recently installed MPGuino.
The one with three buttons on top, all preassembled except for the case and connecting cords.
Love it!
Anyway, I read some cautions about disconnecting it.
What's the best way?
I want to reroute the wire harness; I keep hitting it with my clutch foot. I threaded it through an opening in the lower dash panel and it would be good to be able to disconnect the Guino to reroute the wires.
I put a 4-pin connector in the cable, down in the lower dash area. I could pull that one apart. I also have a fuse in the 12V line, between the battery and that connector. Good idea to remove the fuse before pulling apart the 4-pin connector under the dash? The small connector at the Guino is not so easy to get at. All wrapped up in electrical tape and there's braided sheathing over the cable harness there.
Check your tire pressure - keep it up !!
We've learned that diet has a closer relationship to cancer than we ever thought. Please see this Wikipedia article on The China Study.
Driving Lean Burn '97 Civic HX, lotsa mods by now! '89 Volvo 240 is semi-retired. I did love that car though!
Old 04-14-2010, 09:35 PM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
the recommendation is to be deliberate when connecting or disconnecting the power. I think there were some issues with the atmega flash getting corrupted back when I still used the bootloader and power wasn't solid, but just in case...
Also you will lose your tank trip, but no biggie.
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 1010 05-23-2012 07:23 AM
MPGuino rebooting and freezing also... Power issue? tygertec OpenGauge / MPGuino FE computer 28 04-17-2011 04:05 PM
Speedo Accuracy with MPGuino :-( hummingbird Instrumentation 4 04-07-2010 12:26 AM
MPGuino Hookup (WIP) squriellord Instrumentation 10 03-15-2010 09:40 PM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 05:35 PM
