Old 11-30-2007, 01:24 AM   #1 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
DIY - Black Trim Painting
So, guess who's painting all his trim? This is mainly a DIY for my site but I like to post my stuff up here since this is where I got my start writing DIYs, , nothing to do with FE of course.
Anyway, it's unfinished, but big, so working in parts!
Before shot:
Before bumper:
Using two or three cans of this for the whole deal:
Piece of coroplast over a trashcan in the garage, my painting center:
An MID picture in here for no reason, that comes out to ~52 mpg for a 3 mile cold start, not bad:
Start by taking the two screws that hold the corner lights in and taking the lights out:
Make sure to store everything nicely:
Tools needed, that socket is a 10mm:
Take these two out on each side:
And this one on the bottom, this will allow you to remove the t-bar:
Get these two bolts gone:
Two of these on each side come out, might have to move the wheel a bit:
Two of these corner jobs:
Move the t-bar to expose these three things:
Start pulling the bumper off and unplug the bumper lights:
But it somewhere not scratchy:
To get at the fenders undo these two:
These three up top:
This one in the crack. Use an open-ended wrench and open the door, stand outside and reach over and do it from the crack, you'll see what I mean:
Get these screws on that bottom trim piece:
The bolt on the bottom as well:
When it's off hit up these two last bolts for the fender:
Get bored and work on this piece of trim instead:
Blast it with the hose, the suds, the hose:
Then clean it with alcohol and let it dry:
Here it is drying:
Work on the rocker panel while it dies, these plastic screws suck, you need to be very careful, especially with the ones that are more exposed:
Yay, I stripped one:
Grabbed the edge with some pliers and turned it out like that. I always leave the last few threads in the thing and use them to pull the whole thing out as one:
Some more up top:
Even more up top:
Now, get bored of that and work in the other piece that on the door. Take off this 10mm plastic nut:
This is how it clips in along the bottom, the first task is to unclip:
Half unclipped first:
Go ahead and fully unclip and then push up to get it off the metal rail:
Get bored again and decide to finish the fender, undo all the plasticy junk in the wheel well:
Fender out:
Flip it over to expose the two clips for the trim piece, pop them with some pliers:
Yay, it's so pretty:
Hit that first piece with some paint, drying at this point:
Not that this is a vertical line spray, you need to hold the can vertical to keep it going and work in a smooth, sweeping motion:
With time, there will be more.
Old 12-29-2007, 11:02 AM   #2 (permalink)
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
those plastic retainers w/ small plastic screw in the middle can be removed veerryy easily with a small pointed pick. Put the point of the pick into the screw portion just under the head where it meets the wide part of the body and pry gently. a screwdriver will tear them up in a heartbeat, once the head is out 4 or 5 threads just pull like you were. whole retainer comes out and is re-usable. BUT if you accidentally destroy one they are available on NAPA.com i believe they were 10 in pack for $5. S.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
Old 12-29-2007, 12:01 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
That's for the tip! I never even though of buying more,
I'll have to get a pick at some point, too.
Old 12-29-2007, 12:34 PM   #4 (permalink)
I didn't think about buying them until i need quite a few for my interior. My local Chevy dealer wanted $1.5 (approx, my memory is fading) for a two pack. Google here i come. lo and behold it led me straight to NAPA. S.
Old 12-29-2007, 01:25 PM   #5 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
Which is why I don't like going to a dealer for parts because everything costs 3 times as much as you can buy it across the street!!!
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 11-20-2008, 11:10 AM   #6 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Is that a texture paint?
Because I've been considering how to finish my JettKamm - and I'm thinking of a black texture - like die injected plastic trim bits. Will hide imperfections, give it a "stock" look and is generally easy to apply.
Or I might buy my father (who does finishing professionally) a throw away gun and see about painting it with glossy black epoxy paint
And omg picture overload!
Challenge me, or correct me, but don't ask me to die quietly.
Old 12-13-2008, 04:39 AM   #7 (permalink)
Hi, I am a 24 years old. I am currently taking a beginners painting class, and I am also an art major. I seem to always fall under the same style of painting, mostly impasto impressionism. I would really like to break away from this style. I thought about doing my next assignment based on a portrait with best technique, but I am afraid on how to begin with this and what sort of brushes I should use. Any helpful recommend will be greatly appreciated.
canvas photo
Old 12-13-2008, 12:09 PM   #8 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
Hi, I love tomato bisque soup and I'm wondering if you have any suggestions on how to make my spackle taste more like tomato bisque soup. Right now I have a lovely bunch of coconuts sitting in a row; large ones, small ones, some as big as your head. But, yes, we have no bananas today.
Seriously?
Nice thorough work so far SVO
Old 12-13-2008, 10:59 PM   #9 (permalink)
gascort's Avatar
Gascort - '93 Escort Wagon
90 day: 43.01 mpg (US)
Seriously?
Usually, ROFL is an exaggeration...
I apparently need to move to warmer climes; it looks warm there with green grass and no socks/shoes on 11/30...
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 12-13-2008, 11:30 PM   #10 (permalink)
Dartmouth 2010
SVOboy's Avatar
I am also confused.
