Old 07-12-2017, 11:00 PM   #1 (permalink)
DIY cap for box truck
I ended up getting a box truck and needed the extra room,
Making my own cap because I couldn't find a used fiberglass one.
Made the frame out of old bed frame angle iron,
With some wood screwed to it it help hold the galvanized sheet, and interior walls.
Galvanized sheet is from broken washing machines. Those things are gold for free sheet metal.
Need two more washing machines and it'll be all buttoned up.
Tried to go as aerodynamic as I could in the time I have and balancing the extra storage/sleeping room I require.
It's better than a big flat wall, so I'm happy.
Sliced my hand today on that sheet, bled like crazy.
But yeah, figured I'd post.
ID:	22174  Click image for larger version
ID:	22175  Click image for larger version
ID:	22176  Click image for larger version
Old 07-13-2017, 05:05 AM   #2 (permalink)
Custom User Title
Gasoline Fumes's Avatar
Nut Wagon - '91 Honda Civic Wagon DX
Wagons
90 day: 63.53 mpg (US)
CRXFi - '88 Honda CRX XFi
I think the top needs to be curved, not a sharp angle. What happened to the door?
Best tank with the Honda so far is 81 MPG.
Old 07-13-2017, 08:24 AM   #3 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 34.92 mpg (US)
Those sharp corners on the leading edges, both sides and top, are a problem. They should have at least a 4 inch radius.
I like the workmanship.
The vacuum gauge plus wheel covers helped increase summer 2015 mileage to 38.5 MPG, while summer 2016 mileage was 38.6 MPG without the wheel covers. Drove 10,708.4 miles in 2017 at 35.5 MPG.
Old 07-13-2017, 12:05 PM   #4 (permalink)
It's not done by a long shot.
The sheet is thick enough that it's going to float on the frame for the most part, and after it's skinned I'll be adding sheet metal rounded caps over any sharp edges.
It's no dymaxion, but it's a work in progress.
There's a nice curve across the front that will help a bunch even if the top leading edge isn't perfect.
Old 07-13-2017, 12:40 PM   #5 (permalink)
It's no dymaxion...
How's the robot band going?
Old 07-13-2017, 02:39 PM   #6 (permalink)
Killing it.
We got a bit smaller and way more brutal music.
Pretty heavy grindcore.
Got this truck cuz my old camper just got too tired.
I miss it tho
The Following User Says Thank You to capturedbyrobots For This Useful Post:
freebeard (07-13-2017)
Old 07-13-2017, 03:37 PM   #7 (permalink)
"We play both kinds, music and grindcore:".
capturedbyrobots (07-13-2017)
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
