Old 05-03-2014, 10:53 PM   #1 (permalink)
Old Blue - '91 Honda Civic LX
90 day: 38.71 mpg (US)
DIY/Cheap mirror delete
I removed my passenger mirror and made a cheap/free cover for it, I have not installed it yet because it has been raining and I think I am going to silicone it on (which won't cure in rain)
So, here is were the mirror used to sit
Name:	old mirror.jpg
Here is the old mirror
Name:	old gasket.jpg
This is the old gasket that I used as a stencil to make the cover
This is what I made the cover out of, it is the middle of a lid for a plastic tote. We cut the middle out of the lid so we could use it for our chicken brooder. Anyways, it was just layin around the garage, so I decided to use it.
Name:	cover on car.jpg
This is the cover mock up on the car. I have already done the final fitting and painted it, it just needs to be put on the car. I am going to use silicon to make sure it doesn't leak or anything. I'll post pics when it is done and let you know if I have any air leaks or anything. Thanks for checking out the post. Got any ideas or anything else to add, please feel free.
The Following 2 Users Say Thank You to Jay-Rod For This Useful Post:
ecoTex (05-06-2014), jeff88 (05-04-2014)
Old 05-04-2014, 09:49 PM   #2 (permalink)
Lots of Questions
Motor-Rolla - '01 Toyota Corolla LE
90 day: 28.3 mpg (US)
Gaia - '99 Toyota 4Runner SR5 Highlander
90 day: 19.78 mpg (US)
Gaia - Round 2 - '99 Toyota 4runner SR5 Highlander
90 day: 17.3 mpg (US)
It looks like a good start, can't wait to see what the final product ends up looking like. Are you going to reuse the original gasket or rely on the silicon? I especially like the use of extra material instead of throwing it away or buying new stuff, good re-use/recycling!
Also, I assume you checked your local laws about side mirrors...
Don't forget to like our Facebook page!
Best EM Quotes:
It has been said, that if you peel the duct tape back on Earth's equator, you'll find that the two hemispheres are held together with J B Weld.
Originally Posted by Dan9 View Post
subscribed with a soda.
If you're burning,and someone throws gasoline on you,there will be a localized cooling effect, but you're still on fire.
Old 05-04-2014, 10:32 PM   #3 (permalink)
Yes, I did check with local laws, you need a mirror attached to the side and either a center mounted or additional side mounted mirror. I wound up getting impatient and just siliconed them in the rain and covered it with a plastic bag. There's no end in sight to the rain.
Old 05-04-2014, 10:34 PM   #4 (permalink)
Anyone ever replaced a side mirror with a motorcycle mirror and noticed any difference? I mean, you can pick one up on amazon for like ten bucks, but if it doesn't make a difference, then ten bucks is ten bucks.
Old 05-04-2014, 10:40 PM   #5 (permalink)
http://ecomodder.com/forum/showthrea...ror-23623.html
Old 05-05-2014, 10:24 AM   #6 (permalink)
Not banned yet
deejaaa's Avatar
Blue - '03 Chevy S-10, LS
silicone emits acetic acid on cure and reacts with steel. neutral cure silicone is best. not much steel except that screw so you should be good.
ASI 335 Neutral-Cure Silicone Sealant/Adhesive
2003 S-10, 2.2L, 5 speed, ext cab long bed.
So far: DRL delete, remove bed mount toolbox.
Old 05-05-2014, 10:02 PM   #7 (permalink)
TheManVan's Avatar
Looks nice! Some mirror deletes are UGLY! Nicely done.
Old 05-06-2014, 03:50 AM   #8 (permalink)
90 day: 29.44 mpg (US)
Old 05-06-2014, 10:14 PM   #9 (permalink)
Slow Silver - '09 Chevy Cobalt XFE Coupe
90 day: 37.56 mpg (US)
GMC pickup - '86 GMC C1500
Hephaestus - '09 Kawasaki Vulcan 900 Custom
90 day: 47.13 mpg (US)
The side mirrors on my cobalt are kinda triangle-shaped, I've been thinking about switching the left/right mirrors and mounting them so as to have a bit slimmer profile. Instead of the "point" of the housing protruding outward, have it point upward. Like rotating a 30/60/90* triangle.
