Old 12-30-2007, 05:35 AM   #1 (permalink)
The Mighty Mira - '92 Mira
90 day: 61.32 mpg (US)
DIY Frontal Area Measurement
Apologies if this is somewhere else, but this way is fast and very accurate.
1. Find yourself a time somewhere between morning and afternoon (with good light).
2. Measure how high the car is, roughly.
3. Take a picture from directly in front of the car, at a height a half of your car's height, at least about 10m away from your car.
4. Download the Free and Open Source Software program, "The GIMP". GIMP stands for GNU Image Manipulation Program. If you use Ubuntu, it is in the repositories (synaptic or add programs).
5. Open up the picture in GIMP. Notice the point on the car for maximum height. Go out and measure from the ground to this point with a tape measure, taking care to eliminate parallax error from your measurement. Note this. Then measure the distance from the outside of the right front wheel to the left front wheel. Go back inside and to the GIMP again.
6. You will want to select around the car, so that nothing sticks out beyond your selection. Leave a little border around the car. Use the rectangle select.
7. Go to Edit -> Copy, then Edit -> Paste as New. This will have the car zoomed appropriately, if not, use the zoom commands in the View menu.
8. Save the new image.
9. Press "b" for "Create and edit paths". Or it's the upper right icon in the toolbox.
10. Select around the outline of the car as best you can, for curves, you will need more points than straighter sections. Try and be as accurate as possible. When you are done with the car and your dots are almost at the beginning, select "Create Selection From Path". You should get a nice little flashing outline of your car.
11. Go to Layer-> New Layer, and create a new layer with fill type transparency.
12. Use the bucket fill to fill the selection.
13. Go to Dialogues, Pixel Count. That is the number of pixels in your selection, which corresponds to the frontal area of your car in pixels. Note this figure. Now you just have to convert pixels to real area (m^2 or feet^2).
14. Measure the height in pixels of the highest point of the car, to the ground, using the measure tool (looks like a drawing compass in the toolbox). Or Tools -> Measure.
15. Measure the width in pixels between the outsides of the two front wheels (same span measured in 5.)
15. Once you have this, get height/pixel = Height obtained in step 5/ Pixels measured in Step 14. Should be a small number, much less than 1.
16. Get width/pixel = width obtained in step 5/ Pixels measured in Step 15.
17. Multiply the two number obtained in step 15 and 16. Should be a smaller number yet, even closer to zero. This gives you area/pixels.
17. Multiply the number obtained in 17 by the pixel count obtained in 13. This will give you the frontal area of your car in whatever units you were using.
Now that you have a very, very accurate frontal area of the car, you can compute your drag coefficient more accurately, once you have CdA (which the coast down test will give you).
"Every body perseveres in its state of being at rest or of moving uniformly straight forward, except insofar as it is compelled to change its state by force impressed." - Isaac Newton
Old 11-30-2008, 05:31 PM   #2 (permalink)
fanamingo's Avatar
Bump for a useful thread I just stumbled across in my searches. A couple suggestions for anyone else trying this:
  • Instead of taking a picture of your car (including camera distortion), you may find more accurate renderings at The-Blueprints.com - 26874 visits today.
  • Many manufacturers publish height and width dimensions. Keep in mind that width dimensions may not include the side mirrors.
  • If you can find a simple black and white linedrawing for your car like I did, you can use the Select by Color Tool for a quicker way to determine your car's outline.
  • In step 13, I went to Dialogs -> Histogram to find the pixel count.
I calculate the frontal area of my 8th gen Civic to be 22.8 square feet. I've been trying to find that number for a while now. Thanks, newtonsfirstlaw!
Old 12-01-2008, 11:18 AM   #3 (permalink)
dichotomous's Avatar
CivySi - '03 civic SI
90 day: 31.99 mpg (US)
this technique works better in CAD software. I can pull in a photo, scale it to real world dimensions, trace the exact outline and it will tell me the frontal area in whatever area units I feel like..
I might be inspired to do this for someone with a good picture and measurements, now and then...
Old 12-01-2008, 12:24 PM   #4 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
As long as you know one actual dimension of any part of the car shown in the photo/diagram, the math is pretty easy for calculating area with Photoshop.
See also: Different ways to measure/calculate frontal area (A)
Different ways to measure/calculate frontal area (A) MetroMPG Aerodynamics 23 04-20-2010 11:52 PM
