Old 03-19-2011, 11:23 AM   #21 (permalink)
Mechanical engineer
Vekke's Avatar
Siitin - '98 Seat Cordoba Vario
90 day: 58.56 mpg (US)
VW Lupo 3L --> 2L - '00 VolksWagen Lupo 3L
Diesel
90 day: 104.94 mpg (US)
A8 luxury fuel sipper - '97 Audi A8 1.2 TDI 6 speed manual
90 day: 64.64 mpg (US)
Audi A4B6 Avant Niistäjä - '02 Audi A4b6 1.9tdi 96kW 3L
90 day: 54.57 mpg (US)
Tourekki - '04 VW Touareg 2.5TDI R5 6 speed manual
90 day: 32.98 mpg (US)
A2 1.4TDI - '03 Audi A2 1.4 TDI
90 day: 45.68 mpg (US)
A2 1.4 LPG - '02 Audi A2 1.4 (75hp)
90 day: 24.67 mpg (US)
Answer was already there. Miniature full size truck is 100mmx150mm=15000mm2=0.015m2
with that 5% rule I get cross sectional area of 300000mm2=0.3m2=3.3 square feet.
In cross sectional dimensions this means 450mmx665mm
That was good tip to make that tunnel portable. There is only one problem you should be able to put that car you are measuring on the side of your car. Otherwise your cars aerodynamics would influence to the cars you are measuring?
Can then some verify that same cross sectional rules apply to water tunnels?
https://www.linkedin.com/in/vesatiainen/
Vesa Tiainen innovation engineer and automotive enthusiast
Old 03-19-2011, 11:38 AM   #22 (permalink)
Thanks for posting to this thread -- I'm building a 1/4 scale model of CarBEN and I'd like to build a wind tunnel to tuft test it. The model is 41" long at it's longest points, and 16 1/2" W x 16 1/2" H -- does this need to be 38 sq ft opening? That's a little more than 6' x 6' ... and then how long would it need to be?
Old 03-19-2011, 12:23 PM   #23 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
justpassntime,is there some specific info your seeking? I know you're aware of Reynold's Number effects, and how it effects model scaling in wind tunnels.A 1:24 Scale model would require a minimum of 480-mph wind in the test section to just simulate a turbulent boundary layer on your model .Anything short of that would yield meaningless data for you.If there's something specific you'd like to know about your car or potential projects,we may be able to help you out.I have a small tunnel I built for public demos but it's not a serious research tool.And for me,I can intuit and tuft-test in full-scale,faster and cheaper than I ever could with models.And the results are always valid 'cause its full-scale.Let us know.
From other topic aerohead has pointed out that the wind speed needs to be quite fast 480 MPH on smaller scale 1:24 models :/. That sounds like a small problem
Old 03-19-2011, 12:26 PM   #24 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
Typically,you need 6-pipe diameters length of tunnel to kill vorticity and get nice even laminar flow into the test section.If yo do circulation,you can save on power but you have to do alot of full area turning-vanes at every corner and then maybe flow-straighteners before the test section.
There is the answer so 6x width of the tunnel?
Old 03-19-2011, 12:28 PM   #25 (permalink)
Mechanical engineer
Vekke's Avatar
Diesel
A spray booth would make a great test section.They are smooth-walled and have recessed lighting.Frontal area of model would be limited to 5% of test-section area,so size of booth would determine maximum size of model.Remember,without a turbulent boundary layer your results would be garbage.In full-scale you need at least a 20-mph air velocity for proper Reynold's Number.At 50% you'd need 40 mph.25% -80-mph,and so on.Pope has a great book on" low-speed wind tunnel design."It's worth checking out.The re-circulating design is cheapest to operate,although if using smoke you've got to design for that.
Again from other topic: on your 1:4 tunnel you need 80 mph wind speed .
Old 03-19-2011, 01:57 PM   #26 (permalink)
Cd
Ultimate Fail
Cd's Avatar
I have a knucklehead idea that borders on the ridiculous, but here goes :
If you want to test a scale model of a car with a true 65 -70 MPH windspeed, you could test it in the bed of a truck mounted high to avoid the turbulence from the cab.
Sorry if that has been mentioned before I didn't read everything here.
Old 03-19-2011, 10:54 PM   #27 (permalink)
I'm not looking for a Cd number; all I want to do is tuft test and find the problem areas, so the proper velocity is not critical.
Old 03-20-2011, 09:28 AM   #28 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Outside the bun
Neil, obviously a wind tunnel is for understanding full field flow, but I wonder if you might get any insight by testing specific regions with a leaf blower...
Recreation Engineer
The Following User Says Thank You to KamperBob For This Useful Post:
NeilBlanchard (03-21-2011)
Old 03-20-2011, 12:55 PM   #29 (permalink)
AeroModder's Avatar
Tank - '96 Ford Aspire 4 door
Team Ford
90 day: 46.75 mpg (US)
You mean like this?
In Reason we Trust
Old 03-20-2011, 05:59 PM   #30 (permalink)
Gen II Prianista
Rokeby's Avatar
A very interesting topic for thought experiments. I suppose almost everyone
who has even a moderate interest in vehicle aerodynamics harbors a secret
desire to build a backyard wind tunnel.
Of all the possible configurations, my musings have settled on an open air
arrangement. Perhaps it's overly simplistic, but I have been thinking:
* Get a piece of level land in an area that is frequently very windy
(*See refs below.)
* Ensure that there is a clear path upwind; no trees, buildings. etc.
* Install a ground-level turntable (~ 20 ft diameter?) to point car upwind.
* Have rollers so powered wheels can drive un-powered wheels to wind
speed.
* Do smoke/tuft tests to your hearts content including wind off-center line.
It seems like all the height, width, and length issues would not apply.
With luck, if you built it ,""they would come."
Of course some accomodtions would have to be made for non-windy days/nights.
* Windy US places refs:
Wind Energy Resource Atlas of the United States, Map
Wind Energy Resource Atlas of the United States, Text Descriptions
Top 10 US Cities Weather Facts and Extremes
Cars compared in wind tunnel Bearleener Aerodynamics 30 08-26-2011 05:38 PM
Homemade wind tunnel? justpassntime Aerodynamics 17 06-05-2011 03:17 PM
tuft testing, vortex generators, and God's own wind tunnel jim-frank Aerodynamics 10 06-27-2009 02:48 PM
Virtual Wind Tunnel rockorager Aerodynamics 1 06-03-2008 05:34 PM
Rolling Wind Tunnel CFD trebuchet03 The Lounge 25 04-25-2008 09:06 PM
