Go Back   EcoModder Forum > AltModding > Saving@Home
Old 08-24-2010, 09:15 AM   #11 (permalink)
Old Retired R&D Dude
Little Red - '12 Toyota Prius c 2 Two
90 day: 57.82 mpg (US)
"Whitey" Bulger - '14 Toyota RAV4 LE
The inventor (above?) seems to think I'm on the right track, in understanding the function of the flux capacitor gizmo..
See his comments on youtube..
Cheers,
Rich
Current ride: 2014 RAV4 LE AWD (24 MPG)
Wife's Pizza Transporter
Old 08-25-2010, 10:33 AM   #12 (permalink)
Originally Posted by WisJim View Post
And of course, since it isn't UL listed to the appropriate standards, it can't be legally connected to the grid, whether it works or not.
Use a low voltage transformer that is UL listed. The circuit you connect to it would then be exempt since it is low voltage and isolated. (You might have to put the low voltage circuit in a separate enclosure for that to apply but I'm not sure.)
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 08-25-2010, 11:58 AM   #13 (permalink)
If the device shown in the video does indeed work and doesn't introduce garbage onto the sine wave,
it's very likely it would work just fine with a transformer. And of course be a lot safer to tinker with.
Maybe one of those old 20 pound low voltage/high amps transformers that most Hams have stored in the basement.?.
Used to be a lot of those around for computer power, before Choppers became so popular..
Cheers,
Rich
Old 08-29-2010, 12:17 AM   #14 (permalink)
Tiny Grid Tie Inverter Unit, Maybe.
Not a very good design but it's a nice starting point.
Old 08-29-2010, 12:30 PM   #15 (permalink)
There are a few DIY designs floating around on the web, but none with so few parts..
(And none so unsafe)!!
I'm too old to be working on that kind of stuff..
Just making mods to the stuff I already have is enough to keep me busy..
This thing needs a lot of work..
Cheers,
Rich
Old 10-11-2011, 03:45 PM   #16 (permalink)
Tijeff's Avatar
Hum
This could work. Great idea for the simplicity.
Triac are being trigered by the sector, and the capacitor bost the voltage of the battery up to the grid (Even if I doubt it can do it )
BUT !
If it work
It will distor the AC and introduce some mighty harmonics into the grid and your house
On a little scale that is not that bad, but on a higher level you may end-up having harmonics issue in your home appliance. Motor and transformer overheating, buzz sound in tv and speakers. On a event higher lever, you local power grid company may chasse you up for problem in neighbor houses.
Perfect is the enemy of better
Old 10-11-2011, 04:26 PM   #17 (permalink)
Tijeff's Avatar
As for the 100% efficiency conversion , this is bull****
What is the heat sink there for then?
Triacs will drop some voltage when current will pass true .6v to 1v typically
Voltage drop x current = watts dissipated it heat
No magic here
I'm really intrigued by this design ,,, I love simple design... I'll do a serious Microcap electrical simulation this week , I'll keep you in touch
Old 10-11-2011, 10:12 PM   #18 (permalink)
I hear a lot about losses in things like SSRs, which I use for a lot of things.
DIY 230vac adjustable power limiter - EcoRenovator
I use large heat sinks most of the time, but have never noticed any
large amount of heat being coming off the devices.
Maybe I'm not running enough power, keeping things under 10 amps..?.
Cheers,
Rich
Old 10-12-2011, 01:25 PM   #19 (permalink)
Tijeff's Avatar
Here is a typical triac
http://www.littelfuse.com/data/en/Da...x_Qxx16xHx.pdf
Look at
Figure 9: On-State Current vs. On-State Voltage (Typical)
You will loose 1.1v at 10Amp
1.1v x 10 amp = 11w of heat to dissipate
Old 10-12-2011, 01:35 PM   #20 (permalink)
Tijeff's Avatar
After mutch simulation
This desing
RPM Independent Induction Generator
Just does not work
The triac firing could work , but no way it's gonna take energy from the battery to insert it onto the grid
DIY Solutions to Honda Hybrid Battery Problems (Insight, Civic, IMA) RobertSmalls Hybrids 265 06-18-2020 02:15 PM
I want to get to the bottom of this ethanol killing my mpg Nerys General Efficiency Discussion 175 08-16-2012 08:32 AM
Inverter coolant pump bwilson4web Hybrids 15 08-03-2010 04:40 PM
DIY solar - to - grid tie shovel Saving@Home 10 03-30-2009 09:37 PM
EVs to stabilize grid? Frank Lee Fossil Fuel Free 11 02-13-2009 12:56 AM
