Go Back   EcoModder Forum > AltModding > Saving@Home
Old 10-12-2011, 01:39 PM   #21 (permalink)
Old Retired R&D Dude
Little Red - '012 Prius c 2 Two
90 day: 26.38 mpg (US)
Transporter - '09 Escape XLS
I can run my Sanyo (via two SSRs) at 4 amps 24-7 and the heat sink doesn't get
any warmer than 72 degs F.. (With the air temp between 65 & 70 F).
Maybe that's the 5 watts of wasted power..
That big heat sink was a waste of metal... I could have bolted the SSRs onto plastic..
Cheers,
Rich
Old 10-12-2011, 09:48 PM   #22 (permalink)
Tijeff's Avatar
For shure , disipating 4w is easy
Just Think about your desktop CPU dissipating hundred of watts with a much smaller heat-sink
The only question in electronic design is how much raise in temperature you can allow for your component to survive. In your example, the casing of the SSR itself may be enough to dissipate the heat to a usable temperature
Perfect is the enemy of better
Old 10-12-2011, 10:02 PM   #23 (permalink)
Tijeff's Avatar
This is the result of my simulations of this circuit
I've build it whit closest equivalent pieces available in my simulation software (yes yes I should get the new version , i'm just to lasy to crack the new one )
I've play allot whit components, and tried to tuned it as much as I could
2 possible results
-Circuit does nothing
-Circuit blow out fuses while shorting the grid
Case closed
Old 10-12-2011, 10:15 PM   #24 (permalink)
What's with the 10 ohm resistor in the upper left? Seems like it's nothing but a 1440 watt load on the grid..
Cheers,
Rich
Old 05-05-2012, 08:33 AM   #25 (permalink)
Tijeff's Avatar
Yes it is a load on the grid. Since My ac source is ideal , I need a way to monitor if any current goes back to the grid
Sorry for the delay
Old 05-05-2012, 09:03 AM   #26 (permalink)
LOL! I had forgotten what this thread was about.
When I looked up at the circuit diagram, I was thinking, 'what kind of battery charger is this?'..
Then I went back and saw the Youtube vid.. Something that is was
(until this morning) very dim in my memory.
That's what happens when you get old. You run down to the basement
and once there, you have no clue as to why you are there...
Cheers,
Rich
Old 05-05-2012, 11:02 AM   #27 (permalink)
Eco-ventor
Princess - '92 MX-3 GS
House of Tudor
90 day: 33.52 mpg (US)
Send a message via MSN to jakobnev
In the very first post in this thread, the very first thing i noticed was the capacitor in series with the battery!
That device is simply an expression of wishful thinking!
Remember, even if you win the rat race - you're still a rat.
2010: 454.92L for 5313.90km => 8.56L/100km (27.5MPG US) (5 months)
2011: 606.11L for 7754.04km => 7.82L/100km (30.1MPG US) (Full year)
2012: 170.10L for 2405.00km => 7.07L/100km (33.3MPG US) (In progress)
Old 05-05-2012, 12:18 PM   #28 (permalink)
That was my opinion too. But, it did make me wonder.
If a car battery would be quickly discharged(as claimed),
and if the semiconductors didn't dissipate but a small percentage of the watt hours stored in the battery,
Where did those watt hours go??
Cheers,
Rich
Old 05-05-2012, 03:13 PM   #29 (permalink)
Eco-ventor
House of Tudor
For a 10uF capacitor to pass the charge of a reasonably sized car battery (60Ah) through it, it has to end up with 21.6 billion volts over it. (21600 Coulombs into 0.00001 Farads)
Now most capacitors will break down somewhere () before 22GV, so even if the assumptions were true (they just aren't tho) it would at best be an apparatus for destroying capacitors.
Old 05-05-2012, 07:25 PM   #30 (permalink)
Yeah, I think the cap would have to be a much larger size to pass much current.
Even if the full-wave made it look like 120hz, that's still around 132 ohms of series resistance
(Capacitive reactance XC). Might pass 0.1 amp..
Cheers,
Rich
DIY Solutions to Honda Hybrid Battery Problems (Insight, Civic, IMA) RobertSmalls Hybrids 90 04-01-2012 06:11 PM
Inverter coolant pump bwilson4web Hybrids 15 08-03-2010 04:40 PM
I want to get to the bottom of this ethanol killing my mpg Nerys General Efficiency Discussion 172 07-20-2010 01:06 AM
DIY solar - to - grid tie shovel Saving@Home 10 03-30-2009 09:37 PM
EVs to stabilize grid? Frank Lee Fossil Fuel Free 11 02-13-2009 12:56 AM
