Go Back   EcoModder Forum > AltModding > Saving@Home
Old 09-26-2008, 11:19 AM   #11 (permalink)
the Mule - '99 Dakota
90 day: 14.54 mpg (US)
Nice to see the experiment working for you. And glad to hear you already got the pipes in your basement.
I like the the little water unit two. The combination of those two posts do get the wheels turning a little but I'm not sure where the gyroscope will end up at this point.
Keep it up I,m looking forward to the upcoming posts.
"Without deviation from the norm, progress is not possible"---F. Zappa
If we can't be free, at least we can be cheap"--- Again F. Zappa
My guilty little pleasure
Old 09-26-2008, 01:14 PM   #12 (permalink)
Old Retired R&D Dude
Transporter - '09 Escape XLS
The floor downstairs is still 64.8 and holding steady.
I took the AC downstairs this morning (it's 66 right now) and ran it on the floor for about 20 minutes, set to 65 degrees.
Since it was just pumping heat from the the front to the back, there wasn't any heating or cooling, just some dehumidifying.
Since the coldest air down there is right on the floor, it was a good test to make sure the compressor would come on and stay on.
My test plan is to mount the AC in the wall of the little Landry room.
I'll make a strong platform five feet off the floor, and cut the AC
hole-in-the-wall as large as needed.
The basement intake air 5 feet up will be warmer.. And the cold output air
will sink to the floor.
I'll post again when I've done some more work.
Cheers,
Rich
Old 09-26-2008, 11:38 PM   #13 (permalink)
Another basement test
Did a little testing today and posted it here:
Off Topic Lounge: Yet another heat pump test
Cheers,
Rich
Old 10-07-2008, 11:40 AM   #14 (permalink)
I am doing the same thing with a window unit. I will be disassembling and building my own control unit to allow for regeneration once the coil frezes in the winter.
I will update soon.
Old 10-08-2008, 01:38 PM   #15 (permalink)
Where are you going to get your air source? I think my plan to use the basement air might be limited to under 10,000 BTU..
So, I've been thinking about using outdoor air (like a regular heatpump) and only using it on mild days..
The Airtap HWHP at Airgenerate.com | Adaptive Energy Solutions
seems to do okay down to 32 deg, but I'm pretty sure it's going to get frosted over..
The basement air would be pretty dang cold if you installed 4 or 5 AirTap units in your basement..
Cheers,
Rich
Old 10-08-2008, 03:47 PM   #16 (permalink)
Originally Posted by Xringer View Post
There's a mistake in that picture. The small cylinder next to the compressor is the accumulator, not the expansion valve. The expansion valve is in the line connecting the condenser to the evaporator.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 10-08-2008, 05:12 PM   #17 (permalink)
I was looking at that before and couldn't figure out the gas routing..
Since it didn't look anything like the basic diagram..
What is the expansion valve anyways? Just a tight spot in the pipe?
Could a cut-off valve be used? Have it open part way?
Cheers,
Rich
Last edited by Xringer; 10-08-2008 at 05:14 PM.. Reason: to try and correct spelling..
Old 10-08-2008, 09:38 PM   #18 (permalink)
work truck s-10 - '99 S 10
90 day: 23.64 mpg (US)
Heidis VW - '97 Jetta GLS
90 day: 20.54 mpg (US)
the expansion valve is a device that meters the flow of refriderant to allow for the maximum amount of cooling/humidity removal.
conradpdx, very little copper is involved in a in ground heat pump system, lots and lots of pex pipe is used for the transfer of heat from the ground to the heat pump.
i personaly have a carrier air to air heat pump, rated at a 16 on the seer rating scale and mated to a two stage variable speed 95% efficient furnace, this will be my first winter with a heat pump.
i have the controls set up to change over to the furnace at 30 degrees, air to air heat pumps are way better than they used to be. but still have a ways to go, i am experimenting at my own home, i am a heating and a/c contractor.
and as the technolgy improves we will move into the ground source heat pumps today it requires a very very large investment and so far would be a wonderful investment for the next home owner! but yes they do work
one of the troubles with converting a window unit to use as a heat pump, is what to do with the excess refriderant and installing the reversing valves and other electronic controls, a very expensive task and possible for an experianced heating person to do but with much effort.
Old 10-08-2008, 11:34 PM   #19 (permalink)
"installing the reversing valves"..
Wouldn't those valves be unnecessary for heat-only system?
I've heard that the direct exchange type ground loop systems use copper in their
ground loops. That must be the best stuff to use, if you're pumping refrigerant into the ground loop.
Cheers,
Rich
Old 10-09-2008, 11:16 AM   #20 (permalink)
http://www.ornl.gov/~webworks/cppr/y...res/113424.pdf
By adding heat to the accumulator you can prevent frosting. I am purchasing several programmable temperature relays to allow control of the fan, compressor, and new accumulator heater.
Will be working on this over the weekend.
Brian
Electric water pump Gregte DIY / How-to 84 02-10-2012 12:26 PM
Wood stove radiant heat!??! bennelson Saving@Home 28 07-29-2010 12:39 PM
Geothermal energy? DifferentPointofView Saving@Home 46 02-05-2009 11:15 PM
Synthetic steering fluid for better FE? Gregte DIY / How-to 11 08-04-2008 04:49 PM
Fun with Voltage Controller Heatsinks Dradus Fossil Fuel Free 14 05-02-2008 04:16 PM
