DIY Injector kill switch install. (Honda insight).
Ok guys just brace yourselves, because I'm ludicrously bad at writing these. I didn't take a ton of pictures but yea. It should give you the jist and help you along.
[Edit]: Cowmeat, now you have no excuses :). Ok so, first off, tools and dodads needed (from memory). 10mm socket wrench. Wire cutters/strippers. Crimping tool. Female spade connectors. Pliers. 5-Pin relay (I don't think a 4-pin would work? idk). Momentary Normally open switch, or some form of toggle switch. Wire (duh?) Common sense. Follow basic instructions? So lets begin. First, lets do the wiring from the cabin into the engine bay. This can be very easy, or very difficult, it's just how you personally want to do it. I personally just ran it up the door, I am way to lazy to drill/find another way into the cabin. Remove the 2 10mm bolts on the drivers side fender under the hood, and the one that's parallel to the mirror. As below. https://imageshack.com/i/iqC0NZjcj Pull the fender slightly back, no need to be brutal here, and wire it like so (in this picture I had already put the 10mm bolt back on, as you can see it). https://imageshack.com/i/f07U9Xutj Now that you have the wiring into the cabin, lets deal with getting the injector wires exposed. Remove the engine cover, using the 10mm rachet (again). You will see a plastic cover over the wires, as pictured below, just use a screw driver and brute force to pull it apart. I personally unhooked the metal tubing right above it and moved it out of the way, it made life WAY EASIER working in that area. Careful as coolant comes out of one of the tubes (the one I have zip tied up). In the picture below I had already removed the electrical tape around the wires, I figured just showing you covered wires would be a waste of mine/your time. I also moved the PCV valve tube and this other tiny one out of the way. https://imageshack.com/i/p4X4HtfEj Next, cut the yellow/black wires, but give yourself enough room to work, DO NOT DAMAGE THE OTHER COLORED WIRES, I believe those are what send the pulses to the injectors. Like below. I had already wire-nutted one end so you can see what it should look like. https://imageshack.com/i/iqglvqMnj Continued on next page. |
Both of the wires wire-nutted off and routed to the relay.
https://imageshack.com/i/hlMq2txsj Now you must decide where you want your relay, I opted for next to the battery, I just find that the best spot. If you blow out a rad hose or squirt oil everywhere, chances are you won't get anything on it, and it doesn't get in the way of basic maintenance, (oil change, spark pugs, etc etc). This pic has everything hooked up, so yea. Just showing where I put mine. https://imageshack.com/i/iqtzl6MPj Now, once you have your relay mounted and both of your injector cuts all sorted out, you must get them plugged in! The HOT side of the injector plug goes into port #30 on the relay. You must create a jumper from the hot side to pin #85, this is how I did mine. https://imageshack.com/i/ipy9H6Czj Next, you want to hook up the COLD side of the injectors to the #87A. After that, you want to wire one end of your wires going to your switch into pin #86. Ground the other wire coming from your switch, I used the bolt on the battery box, like so. https://imageshack.com/i/kqji0Slrj |
Now go into the cabin and clean it up! Like so! All done, it almost (almost haha not really) looks like stock!
https://imageshack.com/i/f0jkC92Sj But this, not so much stock. https://imageshack.com/i/ip2jSkcej And that's it! I know I'm horrible at this, but nobody else gave the effort to make this, and I know at least one person will appreciate this. So it's worth my time! If you guys have any questions or comments, please let me know. Here, have 2 more since I can of the engine bay after the install, it looks pretty clean to me. Was worth the 2 hours or so it took to install! http://imageshack.com/a/img537/7937/1Uwz0q.jpg http://imageshack.com/a/img911/6416/4EQeqN.jpg |
I would like to add, I drove around grabbing coroplast election signs (shh...) and I think it was about 10-15 miles around town and it works like a charm, engine dies really fast, and it actually dies with no lugging or other weird symptoms like the coil kill method was causing.
Thanks for posting this, Balto. Too bad the simpler spark-kill method didn't work on your Insight like it did on mine.
Balto, I only see two images at the end of your build thread. Am I missing something? :)
relay attachment
Baltothewolf, That's a great idea how you routed the wires through the door. What is this that you attached the relay to? https://imagizer.imageshack.us/v2/77...674/tzl6MP.jpg |
I have four days off on Christmas weekend, I'm going to install a kill switch then. Couldn't find time while I was on vacation since I had all that other crap to do.
Balto, it looks like you wired all three of the yellow injector wires together. How does that work? Are the remaining wires you didn't cut the ones that send the signal to fire the injectors? I really don't know anything about the wiring, so I'll probably be calling you! Duh, now that I read it again I see you already answered me above! |
