Old 12-03-2008, 02:23 AM   #31 (permalink)
Taurus - '99 Taurus SE
90 day: 17.89 mpg (US)
Windstar1 - '97 Windstar Cargo
90 day: 16.99 mpg (US)
Vulcan - '97 Vulcan 750
90 day: 45.96 mpg (US)
Suzuki - '09 SX4 Technology AWD
90 day: 24.62 mpg (US)
i know you need to use at least 1 resistor because its not all Volts, it has to do with either the watts or amps, i dont remember. the led's cant really handle the something of the feed so you need a resistor to "clean it up."
Old 12-03-2008, 02:43 AM   #32 (permalink)
Misanthropologist
captainslug's Avatar
BORK! - '89 240 DL Wagon
90 day: 21.27 mpg (US)
Originally Posted by Christ View Post
So basically, you'd have to ensure a stable 12v signal to the input in order to run enough LED's to not use resistors at all...
Correct.
If you had a perfectly stable 13.2 volt source you could string six 2.2 volt LED in series with no resistor at all.
The fewer LEDs you have in series and the more resistors you add the wider the input voltage the array can handle without overvolting the LEDs. But you end up consuming more watts with resistors.
4 LEDs in series with one resistor for them will generally offer the best balance between the two.
Old 12-03-2008, 02:50 AM   #33 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
I smell a dirty word... compromise. blech.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 12-03-2008, 08:29 AM   #34 (permalink)
4 leds and 1 resistor, i know is because its specifically for a car i believe.
parallel sets of 4 leds is roughly at 12v per set. but i think the resistor is still required because the line voltage fluctuates between 12ish to 14ish.
dont quote me on this though.
Old 12-03-2008, 08:48 PM   #35 (permalink)
gascort's Avatar
Gascort - '93 Escort Wagon
90 day: 43.01 mpg (US)
I wouldn't waste time with the turn signals; keep them incandescent (just remove one wire from the bulb and use it for your led parking lights. - keep the old bulb in place and just power the high filament)
Unless you spend a huge amount of time with your turn signals on. Less cost, less hassle, less risk of not working and losing hazards as well, and no flasher change to worry about.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 12-03-2008, 09:27 PM   #36 (permalink)
Bah, that's too easy. :P
Old 12-04-2008, 04:28 PM   #37 (permalink)
Red Egg - '95 Aspire
90 day: 38.51 mpg (US)
Dodge SRT-4 - '04 Neon SRT-4 2.4L Turbo
90 day: 26.24 mpg (US)
There are frenched style tail light kits for the jeep TJ/CJ wranglers that use what appear to be the same lights used on big rig tractor trailers. They are dual intensity and can be seen forever. Not so DIY but its a clean install.
Old 12-04-2008, 04:57 PM   #38 (permalink)
but i have a ZJ, a 1994 Grand Cherokee. the "mods" for tail lights are slim. Just Nasty looking Altezzas.
Old 12-04-2008, 11:28 PM   #39 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
I'm a little concerned with the optics of doing this: LED's have such a narrow beam, that getting them actually reflecting and (highly) visible from all angles. Some of the LED replacement bulbs have a center "hot spot" that shines straight back, and they have some around the rim to bounce off of the reflector, so you can see it from the sides, etc. Has anybody tried these?
7443 LED bulb Specifications
3156 and 3157 LED bulb Specifications
As opposed to these:
Old 12-05-2008, 12:36 AM   #40 (permalink)
if youre gonna make your own panel of LEDs to put into the taillight, like i eventually will, they sell "flat top" leds that have a wider viewing angle.
DIY LED Fish Tank Lights bennelson Saving@Home 20 12-28-2011 08:45 PM
LED lighting goes mainstream! It's at Wal-Mart! bennelson Saving@Home 81 08-07-2010 12:18 PM
Flashing yellow light skyl4rk EcoModding Central 5 08-01-2010 02:57 PM
LED X-mas lights bennelson Saving@Home 10 12-05-2008 12:54 AM
Mercedes C Class patented ventilated tail lights MetroMPG Aerodynamics 1 11-28-2007 01:06 AM
