Old 12-05-2008, 01:25 AM   #41 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Or, you coudl use the round ones and eliminate the hot spot by filing the tops of them...
Doesn't really matter, your OEM tail light lens is a light diffuser as well. If you don't relish that idea, put opaque film over the lights before you install them.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 12-06-2008, 08:41 PM   #42 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Man, this is what you do.
"Redneck LED Conversion"..................
Get a pair of junkyard taillamp assemblies
Get a Dremel Tool
Get a lamp like this..........
Get the rubber grommet made for the lamp
Get a 3 prong pigtail made for the lamp (truck stops have all this crap)
Hack out the hole
Insert grommet
Insert Lamp
Wire in both sides
Grab a beer!
Enjoy the show!
I love my LED front turn signals/marker lamps. They really turn heads.......
Old 06-26-2010, 12:02 AM   #43 (permalink)
this is good stuff
Old 06-26-2010, 12:03 AM   #44 (permalink)
I'm a have to try this
Old 06-29-2010, 10:39 AM   #45 (permalink)
jusnicho's Avatar
Midg - '99 Accent HTCBK
90 day: 37.33 mpg (US)
Landy - '02 Discovery II SD
Last 3: 17.44 mpg (US)
Minor in Electrical Engineering. I'll give it a shot
JusNicho
"Drive it like you're
running outta fuel."
Old 08-03-2010, 03:57 PM   #46 (permalink)
Dr. Jerryrigger's Avatar
The Sh*t-Box - '99 Impreza Outback Sport
90 day: 27.81 mpg (US)
So there are a few options for this, first off to use one LED per light or many. With one of these 15watt LEDs you would have enough light, but they overheat (that's why they aren't use for head light much). Or you could use a array of smaller LEDs.
One thing about LED's is that you don't need a red lens, you can just get red bulbs. If you are going to run them under the red lens, then you should know what spectrum the lens lets through. Your lens may block out a lot of light at 640nm, but not at 660nm. To really know; some complex testing would be needed. Alternately you could make clear ones, or drill holes for the LED's to pop out of.
So for controlling brightness there are also a few options.
-Multiple circuits (the option i think is best) in which you would have say 5 rows of lights, and 2 would only be on for the "bright mode" for brakes or what have you.
-Or the PWM (pulse width modulator) way, by running them on a square wave current for dim, and a wider wave or just DC for bright. I don't like this because I also hate seeing them on the road (most stock LED's, but Cadies are the worst). The PWM waists energy, but not as much as resistors.
-Or the resistor way, where you have a bright and dim voltage. This would be a rather simple way to do this, but it's the lest eff way.
For wiring the first bright/dim choice would be simplest, but you would need to find the right LED's, and know the voltage your charging system runs at (not just at idle).
Ideally you could do this with out any resistors
If you have 13.9 to 14.2V take the higher voltage and find a LED that has a max running voltage that can go in to 14.2 some number of times. If you used these 2.8V red LED (just under a half watt each) you could string 5 together. 14.2 across 5 would give them 2.84V across each which should be fine, and at 13.9V it would be 2.78V each.
For blinkers you would be best sticking with the sock ones, but if you must, go with a blinker relay that is made for lower wattage (the specific wattage you end up using). Shorting it out with a resistor works, but it doesn't help anything, you use the same amount of electricity, and instead of changing bulbs, you have to change that resistor every time it explodes.
or you could save alternator draw by just doing this:
Redneck Repair forum
Old 08-03-2010, 04:42 PM   #47 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
Originally Posted by Dr. Jerryrigger View Post
...ah, but how much "loss" do you encounter due to 'bad' arm-aerodynamics (wink,wink)?
Old 08-03-2010, 08:32 PM   #48 (permalink)
Much less than the fact that few people on the road seem to remember these hand-signals. They often respond with hand-signals of their own, most of which weren't covered in the driving manuals...
-soD
Old 08-04-2010, 11:06 AM   #49 (permalink)
...beats walking...
...ah, yes, the universal "...single digit salute..."
DIY LED Fish Tank Lights bennelson Saving@Home 20 12-28-2011 08:45 PM
LED lighting goes mainstream! It's at Wal-Mart! bennelson Saving@Home 81 08-07-2010 12:18 PM
Flashing yellow light skyl4rk EcoModding Central 5 08-01-2010 02:57 PM
LED X-mas lights bennelson Saving@Home 10 12-05-2008 12:54 AM
Mercedes C Class patented ventilated tail lights MetroMPG Aerodynamics 1 11-28-2007 01:06 AM
