DIY lithium pack affordable? (Insight)
Granted, I have seen numerous posts about the cost of Lithium ion battery packs. However, I got curious about the exact cost. I admit, I am waay in over my head on making the computer work, but here is what I found:
On batteryjunction.com they have UltraFire 17670 lithium ion batteries. 3.7v, 1800maH batteries for $5.50 if you order enough of them. I figure if you wired them in units of 4 parallel for 7200maH, then run forty such units in series, you get 7.2aH at 148v, right? For $880! (PS, I may have gotten series and parallel backwards; I understand the concept and the wiring, but I get the words confused sometimes) There are higher aH batteries for sale on there that might offer better cost to benefit ratio, but that was the best I went to the trouble of calculating. If you wired this in with the factory battery pack and added the manual hybrid motor controller, you could maybe keep the assist on almost constantly.
Recharge is way out of my realm of understanding, but if you could recharge at home, this could drastically increase your IMA workload and therefore decrease engine load and stay in lean burn a lot more. Thoughts?
