Old 05-12-2008, 11:16 AM   #1 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
DIY OBDII to ScanGaugeII cable
I was tired of switching my SGII cable between cars now and then, especially since it's routed behind the console in the Elantra. So, I had a male ODBII connector (J1962) lying around from a dead vag-com ebay cable (VW specific diagnostic tool) and decided to make a 2nd SGII cable for cheap.
Here's the mapping between a standard CAT5 network cable and the J1962 connector
Brown - Pin 16
White/brown - Pin 15
White/orange - Pin 14
White/blue - Pin 10
Orange - Pin 7
Green - Pin 6
White/green - Pin 4 and 5
Blue - Pin 2
Facing the connector with the wide side up, pin 1 is in the upper right corner.
You could even make a SGII cable for next to nothing. If you don't have the male connector at hand you could use a junkyard female connector, extend some flattened pins made out of solid conductor power wire and tape it with the other male connector in your car.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 05-12-2008, 12:06 PM   #2 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
This is good info.
I'm fuzzy on your last suggestion about using the junkyard male connector. Could you elaborate?
Old 05-12-2008, 12:24 PM   #3 (permalink)
Moderator
I edited my post. I had the male/female part backwards. Here's a pic I snatched from a pdf of someone who made a female connector. The SGII compatible cable will need more pins though.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 979 12-26-2011 10:37 AM
DIY: OEM VX PCV and Info TomO DIY / How-to 4 04-02-2011 10:38 AM
DIY - Water Injection Stormin' Norman DIY / How-to 45 02-05-2009 05:42 AM
DIY - Basic Fabrication trikkonceptz DIY / How-to 9 05-03-2008 12:10 AM
DIY - Wire Tuck SVOboy DIY / How-to 4 01-25-2008 03:14 AM
