Old 02-15-2010, 10:42 AM   #261 (permalink)
jackbauer's Avatar
Here a few pics of the charger in operation. First pic is running in bulk mode with a 10amp current limit. Second pic in float mode. I had to limit the charge to 10amps due to the poor main service where i work on the car. Was actually causing the lights to dim
ID:	5608   Click image for larger version
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
Old 02-17-2010, 04:32 PM   #262 (permalink)
Paul: Wheres the new thread, on 14 volt, 90 amp DC-DC converter? Mr Bigh: I live on LI. You can call me, and I'll give you all the info/progress. 631-474-1403. Of course, you'll need my real name: Clyde Smith. Kindest regards to all
Old 02-17-2010, 04:54 PM   #263 (permalink)
Wonderboy's Avatar
The Fruit Bat - '01 Honda Insight
Last 3: 54.26 mpg (US)
Current - '21 Subaru Impreza Wagon
90 day: 34.36 mpg (US)
I have been lurking around this thread watching the progress with limited understanding of what is going on. Let's just say the extent of my understanding is that I aced my college digital electronics class. I am poised and planning to try out any or all of these open source EV projects on my conversion. Within this year I will either be buying direct or building my own copy of Paul's controller, this charger (when it's finished), and hopefully the DC-DC inverter. I wholeheartedly support what has been going on here, am proud of it, but unfortunately don't have much help to offer but moral and monetary. Keep up the good work guys, I really appreciate it.
-Will
Old 03-03-2010, 12:39 PM   #264 (permalink)
Hey JackBauer, does your charger charge at the full 40 AMPs required to charge your PC2150s?
I am looking at building my own 40 AMP charger because I am looking into PC2150 (actually the Sears PM-1 31, but same battery) and it requires a 40 AMP charge at least every 5 cycles to properly live, according to the Odyssey engineers.
I have enough parts to build a 6 AMP prototype over spring break, and if I am successful, I am going to go for the big kahunah, 240v charger with 40 AMP output for a 96 volt pack. I am in the middle of taking AC circuits, so building the charger should not be a problem, except maybe actually getting a 240 volt plug in the house...
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
Old 03-03-2010, 01:27 PM   #265 (permalink)
jackbauer's Avatar
It so happens that just yesterday I had the chance to run the charger at near 30amps output for the first time as i had access to a 16amp industrial 240v supply. Worked fine albeit for a short time as the batts were not very discharged. The charger is , in theory , capable of 50 amps output. My inductor is oversized for the job if anything. The new software I developed completely eliminates the noise issue on the voltage readings.
Regards the Odyssey batts i cant sing their praises enough. On my short runs thus far they laugh at the demands made by the motor! I had a chance some weeks back to speak to the european sales manager for odyssey and he advised that when connected in series strings of more than 2 units that they be charged to 14.5v during absorption phase not 14.7v. This is to allow for slight imbalance in the pack.
www.evbmw.com
Old 03-03-2010, 02:19 PM   #266 (permalink)
EVVette - '71 Chevy Corvette Coupe
Wait!? the sears battery is the same as an odyssey??? Do you have a link as to what one it is on their website?? I want odyssey's for my golf cart, but couldn't really afford them, but I could afford these!!
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 03-03-2010, 05:29 PM   #267 (permalink)
-Adam
Yep, the Sears PM series are Odysseys, except with Automotive Posts along with screw terminals. They were made for Sears by Odyssey. This it the one I have my eyes on: http://www.sears.com/shc/s/p_10153_1...rine+Batteries
I am saving up for these batteries, once I build a charger capable of dumping 40 AMPS for charging.
The Following User Says Thank You to TheSGC For This Useful Post:
adamj12b (03-03-2010)
Old 03-03-2010, 06:05 PM   #268 (permalink)
PaulH
MPaulHolmes's Avatar
I have 6 of those exact batteries. 3 year warrantee. I've had no problems for the last 1.5 years.
kits and boards
Old 03-04-2010, 09:52 AM   #269 (permalink)
I want hear about long, abusive runs! Your BMW is similar to my Civic, (96 volts setup) so I am really curious on what your range and performance is with those batteries, and how the charger works out at 40 AMPs.
Old 03-04-2010, 10:05 AM   #270 (permalink)
Hey Dave,
Jacks problem right now is he doesn't have a service big enough that is readily accessible to power the charger that wont cause a tripped breaker or the light dimming!!
Also, right now he only has 48V (4 batteries), but is getting 6 more very shortly.
I dont know how much you have done on your charger already, But I have a PCB of this charger all drawn out in eagle that I will be proto-typing in the next few weeks. Im working on a kit basically that this will be the logic, you supply the power stage which is just a rectifier, caps, IGBT, and inductor.
I could use a beta tester that is local...your only an hour away...If your interested.
-Adam
ev charger
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 1041 07-28-2014 09:19 AM
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 07:00 AM
Open source PCB design dcb OpenGauge / MPGuino FE computer 39 04-25-2010 09:18 PM
Open Source electric conversion information bennelson Fossil Fuel Free 8 02-14-2009 11:23 AM
Open Source LEV Controller FrankG Alternative Transportation 1 03-24-2008 03:10 AM
