DIY open source lithium BMS (battery management system)
2 Attachment(s)
I've made enough progress with my lithium BMS that I think its time to post up what I have so far. I am posting the info for others to use as well as get some feedback.
Let me preface this all with the fact that I am by and far no expert in this. I know some programming and a little bit about electronics. That and a lot of googling and help from others has lead me to developing this. The BMS is currently setup to work with the plugin kit for my Prius. So, right now its very simple. For example, where you see dc-dc converter it would be the controller in an EV. However, it was developed while keeping in mind that I'd like to use a similar version on an EV. With that I'd like to go over generally how it works without having to dive into code: Charging protection is pretty simple. All the cells voltages are individually monitored via a series of celllog devices. The celllog can measure up to 8 cells at once. If more cell monitoring is needed you need another celllog and the tiny circuit that accompanies it. My circuit diagram shows 2 celllogs which is what I am using. The celllog has a user settable high voltage alarm that is used. Once the alarm goes off, the arduino cuts power to the charger. Discharge protection is taken care of via a current sensor. You have to enter in the amp hours your batteries are rated for and the max DOD you want them to see. From there the current sensor will keep track of amp hours used. For my plugin kit it automatically shuts the kit off after I hit my max DOD. For a full EV you could simply not use that part of the circuit. I have added an 8 LED bar graph that tracks SOC of the pack as a 'fuel gauge'. Balancing is currently not done with the BMS. It is designed to have the batteries balanced at the low end of their charge and then put into use. I have yet to find a good way to keep track of the SOC of each cell and balancing makes that much more complicated. Thermal protection is not currently done either. The plugin kit doesn't even pull 1C on the batteries so its not an issue. However, I would be interested in adding this. Here is the schematic: http://ecomodder.com/forum/attachmen...1&d=1340904482 And here is the code (NOT UP TO DATE): Code:
/* http://ecomodder.com/forum/attachmen...1&d=1340907190 I've been using the charging protection for a few months with my plugin kit and it has worked great. I have just finished working on the discharge protection and haven't yet assembled the circuit. Anyway, thanks for reading if you got this far. Its a lot to look at, but I'd really appreciate some feedback. |
I added the bill of materials to the 1st post.
doax that is impressive, i build microcontroller circuits and write code in assembly. if it works well and does not fail its a good design!. for thermal protection you probably already know that you could use negitive or positive temp coefficent thermisters and an op amp to trigger where ever you calibrate it. we use them on our lasertag vests charging systems. im interested in these kits for the pruis,,, i dont have one yet but i am eyeballing them, because of the avalibility of kits to up their mpg. my echo is getting long in the tooth at 199k. and 70 mpg is promised on some of these kits,
Thanks for the idea moonmonkey. I've used lm35 temperature sensors on different arduino projects before. I think if I were going to use some for this project I'd go with a 1-wire type because you could have multiple sensors and I don't have a huge abundance of pins left if I want to keep doing more and more.
doax the pic microcontroller is easy to learn and there is alot of code examples out there to do just about anything you want. the programmers are cheap and tech support ,,,fair. the 16f84 is the one everyone learns on . but i use the 16f877 for most of my stuff because it has 33 I/O that you can program to be any combanation of inputs and outputs, i dont know if you write in assembler but this chip is a risc (reduced instruction set) and has only around 33commands, and cost around $10.00 dollars,then you just need a few resistors,a crystal and a few caps. i have used these chips in some very complex machines, they are rock solid and easy to use once you get used to them.i will be happy to help if you want to switch over to them.im not that knowledgable about arudino, it was'nt out when i started with pic.
I've evaluated all the cells in my pack now, and I know all of their capacities. That means the batteries are ready to go back in the car. So, its back to working on the BMS system to ensure nothing else bad happens again.
This weekend I worked on tweaking the current sensor setup. Its still not perfect, but after a few tests it seems to be accurate enough that I won't be over-discharging anything. I also worked on getting the SOC meter. I got it wired up and tweaked the code a bit to get everything working correctly. I even made a quick video to show how its working. I do have another bargraph on order that is linear instead of having LEDs side by side. We'll see what one I like when that one gets here. http://www.youtube.com/watch?v=30kfzrZImoI |
I like the bar graph your using, with its 1/8 drop off.
The circuity and electronics are foreign to me , but I know a good meter when i see it ! I think your onto a money maker, must be more then one model of hybrid that would benefit from your lithium BMS meter. Maybe your not trying to make money with it, i see a lot of marketable talent here on ecomodder. :turtle: Sales Section here on ecomodder could do well.. |
Thanks!
I have designed the BMS with the thought in mind that it could fairly easily be scaled and tweaked to be used in a full EV. I do have a future project in mind, but its on the back burner at the moment. A money maker it will not be though. I'd really like to keep it as an open source project. The commercial BMS systems are fairly expensive and I haven't found a good alternative myself, so this is the route I am taking. Being open source also allows me to get help from others! I'm far from an expert, and I've already had a bunch of useful input from the guys here and local EV club. Its great to get useful criticism and feedback so it can be further improved upon. |
1 Attachment(s)
I got the new bar graph and I think I'm liking it better. As you can see all the LEDs are in a line so its a bit more straight forward. The size of the two is identical. The only downside to using this graph is that it has 10 LEDs and my shift register only has 8 output pins so I can only drive 8 of the LEDs with it. There are many ways to deal with this, but the fact that you do have to deal with it is something to think about, especially if you want things to look real nice.
http://ecomodder.com/forum/attachmen...1&d=1340844395 |
