Old 11-11-2010, 11:05 AM   #1 (permalink)
Eco-ventor
Princess - '92 MX-3 GS
House of Tudor
90 day: 33.52 mpg (US)
Send a message via MSN to jakobnev
DIY plastic domes
I decided to try to make plastic domes by gluing a cd-cover to the open end of a tin can and sucking out the air through a check valve, after which i heated the plastic with a heat gun.
My conclusion is that i need to use a larger diameter can and get better at heating evenly with the gun.
I plan on covering my non aerodynamic foglights with these.
Old 11-11-2010, 12:01 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Interesting, but I'm having a hard time visualizing them on a car. Got a pic of yours? My first thought is just to use the flat plastic piece and leave it at that.
Old 11-11-2010, 12:57 PM   #3 (permalink)
Cut out the bump, put it on the front of a flat fog-light. At least, that's the impression that I am getting.
It must be the teenager that still lives in my head, but that third pic looks.... mammalian.
-soD
Old 11-12-2010, 09:53 AM   #4 (permalink)
Eco-ventor
House of Tudor
Well that "tit" you see in the picture isn't the final version that goes on the car, i only plan on curving them a little, because the bumper is very strongly rounded at the fog lights and the damn things stick out a little bit, so that a flat piece won't fit.
Old 11-12-2010, 01:38 PM   #5 (permalink)
Suzi - '94 Swift GA
90 day: 48.94 mpg (US)
Prius II - '05 Prius Package 6
90 day: 46.51 mpg (US)
with a plastic CD cover, I would be worried about it cracking when it gets hit with a rock. I have had more than one CD cover break due to flexing.
Old 11-14-2010, 10:34 AM   #6 (permalink)
Your project is right along the lines that I have considered tackling. Please keep up the good work.
old...
Old 11-14-2010, 12:39 PM   #7 (permalink)
Bus - '94 School Bus huge
Stupid - '01 Blazer LS
90 day: 21.38 mpg (US)
hawk - '00 Superhawk
you just need a mold, that is all.
Old 11-14-2010, 12:52 PM   #8 (permalink)
Wolfsburg - '03 Jetta 1.8t
90 day: 28.69 mpg (US)
*youtube video*
and a lot of vacuum, too
Old 11-14-2010, 06:55 PM   #9 (permalink)
NHRABill's Avatar
Tahoe - '95 Tahoe LT
90 day: 13.22 mpg (US)
SRX - '04 SRX AWD
XL - '05 Sportster XL
90 day: 49.97 mpg (US)
Alero - '02 Alero GLS
Corvette - '75 Corvette Stingray
Very creative
A friend of mine once worked at a plastics company Link below. If the heat doesn't work out to your satisfaction
they have clear balls that could be cut in half to fit your needs...
I prefer the bragging rights of the DIY o good luck to ya.
BALLS PLASTIC BALLS FROM COMPLEX PLASTICS 1-888-PLASTIK 1-800-363-2870 SUPPLIERS OF INDUSTRIAL PLASTICS
Old 11-15-2010, 07:20 AM   #10 (permalink)
Eco-ventor
House of Tudor
I'm not overly concerned about rocks, partly because the raw material is free. (in fact, it's better than free because it reduces garbage)
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 34 01-06-2012 11:40 PM
DIY: OEM VX PCV and Info TomO DIY / How-to 4 04-02-2011 09:38 AM
Replacing metal body panels with plastic silverhawk_184 EcoModding Central 8 12-07-2010 07:18 PM
Tap Plastic How-To Videos cfg83 DIY / How-to 4 02-12-2009 12:05 AM
how to make skirts for plastic wheel arches? modmonster Aerodynamics 6 01-22-2009 11:06 PM
