Old 03-06-2008, 07:40 PM   #11 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
Go out to the car, yank your plug wires and then your old plugs.
if you yank them from the distributer, make sure you know your firing order and which one is cylinder 1!!!
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 03-09-2008, 05:37 AM   #12 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
Whats a distributor and a spark plug wire?
direct coilpacks FTW!!!
Old 03-09-2008, 06:09 PM   #13 (permalink)
Liberti
LostCause's Avatar
Thunderbird - '96 Thunderbird
90 day: 27.75 mpg (US)
Did you convert a distributor set-up to a coil-on-plug? If so, how?
I've been brainstorming on how to do it to an obd-1 honda, but their ECU only has one ignition channel. Apart from switching to a new ECU, which would inhibit other desirable features I'd want, I figure replacing the distributor w/ a variable reluctance sensor and distributing the spark signal to the coil packs w/ a demultiplexer would be the way to go...
Just a dream at this stage, but I'd like to know how you did it. I love the prospect of zero maintenance.
- LostCause
Old 03-09-2008, 06:36 PM   #14 (permalink)
EcoModding Minded
Chris D.'s Avatar
factory stuff..
you could go megasquirt..
I did it to my turbo car and it made tuning a breeze..
Old 06-09-2008, 11:16 AM   #15 (permalink)
Harebrained Idea Skeptic
The White Car - '84 300td
90 day: 28.84 mpg (US)
The Blue Car - '86 535i
Last 3: 23.86 mpg (US)
Spark plug indexing is indeed a good 'ol racer's trick, but:
  1. It's much less useful on engines with centrally-located plugs (i.e. go down through the valve cover) than side-entry plugs.
  2. There are more gains to be had by ensuring the plugs are gapped properly. It appears the gap wasn't checked in this instance. As has already been mentioned in the thread, a plug can have multiple applications and it's likely not all of them have the same gap.
Old 06-17-2008, 06:33 PM   #16 (permalink)
MPG...what?
Malibu1 - '79 Malibu Classic
Malibu4 - '79 Malibu Classic
Terkle - '97 Tercel Whitehawk
90 day: 40.91 mpg (US)
Bubble - '010 Yaris base
90 day: 46.84 mpg (US)
Zoey - '95 Protege LX
90 day: 29.29 mpg (US)
Send a message via AIM to malibuguy
^ yep
but try doing it on a Sbc with headers...nuh uh, i ain't doing it, lol
i should tho...i need to put some new plugs in M1
-Greg...the exhaust freak.
www.mandrelbend.com <-- I work there!
Old 06-18-2008, 06:20 PM   #17 (permalink)
ttoyoda's Avatar
SVOboy
You need new gaskets around the spark plug tubes under the rocker arm cover. That oil is not supposed to be all over the old plugs.
Old 06-21-2008, 08:51 AM   #18 (permalink)
OfficeLinebacker's Avatar
I've been given to understand that Platinum +4's obviate the need for indexing.
Old 06-21-2008, 08:30 PM   #19 (permalink)
EcoModding Minded
Chris D.'s Avatar
those are a horrible marketing scheme.
cant change the gap in em,
your only going to get one spark per plug reguardless of points on it..
Old 06-21-2008, 10:47 PM   #20 (permalink)
Yeah but it's going to be the "best" path. If the "preferred" anode experiences wear, there are three others waiting to take up the slack.
I think it's more of a durability thing. I don't know if the path of least resistance is necessarily the best path in terms of combustion.
