Old 10-08-2012, 10:43 PM   #51 (permalink)
Jakins's Avatar
hX-TREME!!! - '97 Honda Civic HX
90 day: 54.75 mpg (US)
450sX-TREME!!! - '95 Nissan V8 240sx
chodercycle - '06 kawasaki ninja zx6r 636
have you noted any MPG gains?
Old 09-13-2013, 06:43 PM   #52 (permalink)
The Truck - '02 Nissan GU Patrol ST
Just found this study on plenum volume and efficiency.
http://muhserv.atauni.edu.tr/makine/..._files/A/e.pdf
Although they talk in terms of increased volume, the experimental design describes the use of throttle body spacing, they found overall improvements from 1,700-2,600 rpm at the expense of reduced performance beyond 2,600.
I'm guesstimating they used around 1" & 2" spacers on the bases of a 2 1/2" diameter intake duct, bigger than 2 inch reduced overall performance.
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
The Mechanism Behind Flow Separation LostCause Aerodynamics 46 07-15-2010 07:38 AM
Big Bore throttle body for MPG? cfg83 EcoModding Central 19 12-31-2008 09:44 PM
Archimedes screw throttle ronarprfct EcoModding Central 29 08-27-2008 03:10 PM
Throttle sensitivity Formula413 EcoModding Central 13 05-29-2008 04:55 PM
