Old 01-08-2013, 08:57 PM   #1 (permalink)
1999 Dodge Dakota
I have a 1999 Dakota 4.6 4x4.....was wondering what are some simple eco mods i can do to improve mpg....fastest i go is 60 and get about 17 mixed highway/town
Old 01-08-2013, 09:24 PM   #2 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
As far as simplicity it is going to be the same mods everyone suggests
1) bed cover, not a cap unless it is an aerocap
2) smooth wheel covers
3) lowering or arch gap fillers as found on our list 65+ Vehicle modifications for better fuel economy - EcoModder.com
4) buy a FE gauge
5) adjust the nut
6) fill up tires
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 01-09-2013, 01:08 PM   #3 (permalink)
o - '84 Ford F150
if im not mistake your truck should have an electric fan and engine driven fan on my friends we pulled the engine driven fan and swapped in a set of under drive pulleys at the same time and he got 2-4 mpg. in the 2 years since we pulled the engine driven fan the electric fan rarely ever comes on
Old 01-09-2013, 01:12 PM   #4 (permalink)
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
I don't think so. E-fans started getting installed on Dakotas, only beginning in the 2000 model year.
That being said, it should easily be possible to retrofit an e-fan to OP's Dakota. Though I am not familiar with a 4.6L engine in a Dakota. 1999 model year Dakotas came with a 2.5L I-4, 3.9L V6, 5.2L V8, or 5.9L V8.
Old 01-09-2013, 01:38 PM   #5 (permalink)
justme1969's Avatar
Hmm other than those mentioned gear up or get a larger diameter back tire if rpm is high on interstate., front spoiler or air dam. dont forget that a more efficient engine makes better use of its fuel, my 99r/t has come a long way with no special mods; well sorta for a gas sucking pig truck.
Old 01-09-2013, 01:48 PM   #6 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Grille blocks (as much as you can)
Air dam (Can do with lawn edging for <$20)
Wheel covers (coroplast cut into circles and zip tied to spokes)
And cover the rear half of the bed, if you're not up to making an aero topper. GM holds a 1984 (?) patent on covering the rear half, claiming it's more efficient than covering the whole thing. By any account, the differences are pretty close. But buying a half sheet of plywood is cheaper!
http://ecomodder.com/forum/member-sv...ture4138-a.jpg
The Following User Says Thank You to Sven7 For This Useful Post:
justme1969 (01-09-2013)
Old 01-09-2013, 01:50 PM   #7 (permalink)
MPGuino Supporter
t vago's Avatar
Covering the bed (even covering just the rear half) does not work with 3d generation Dakotas.
The Following User Says Thank You to t vago For This Useful Post:
Sven7 (01-09-2013)
