Old 04-29-2011, 02:19 AM   #1 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
Do these window shades work?
A lot of cars here have "sunshades" suck to the inside of their windows:
They are just a black net/mesh, so I wonder if they actually help to lower the vehicle's temperature, as the manufacturer claims. Yes, they reduce the amount of direct sunlight hitting the passengers, but they do not reflect sunlight back out of the car (unless invisible heat/infrared is reflected). My guess is that they absorb direct sunlight and emit it as heat.
What do you think?
I've seen a few cars with white versions of these, and I'm willing to believe that these work, but I can't find any which aren't black.
Piwoslaw's Peugeot 307sw modding thread
Old 04-29-2011, 04:42 AM   #2 (permalink)
White will reflect more light, both ways. It will be harder to see through the white than the black.
I usually see these used for a child,s seat where they are not tall enough to get their face up into the shadow of the roof. I agree that the black isn't going to reduce interior heat build up much, if at all.
Old 04-29-2011, 04:44 AM   #3 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
The moment the heat is through the glass and gets transfered to the air inside the car, most of the damage is done.
They'll help a little bit - even black reflects heat - and will keep away direct sunlight, so it feels a bit more comfortable.
Lifetime fuel consumption :
Old 04-29-2011, 06:15 AM   #4 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
The Infiniti has these built into the window sills in the back doors.
I still have the max legal tint applied to the window AND have a static (removable ) film on the window.
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 04-29-2011, 10:47 AM   #5 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...I've used them. They work OK at keeping "direct" sunlight off of you and the passenger(s), but do NOT reduce the incoming solar-induced thermal load (heat), so A/C works just as long & hard as before...BUT, since you (and passenger(s)) aren't receiving direct sunlight, there *IS* a better 'comfort zone' than without them.
Old 04-29-2011, 11:09 AM   #6 (permalink)
mcmancuso's Avatar
Green Metro - '99 Metro LSi Sedan
90 day: 32.78 mpg (US)
Metro Vert - '91 Metro LSi Convertible
90 day: 50.52 mpg (US)
I've had some that are white on the outside and black on the inside, better visibility and heat reflecting than solid either color, don't know where they came from, they're pretty old.
Old 04-29-2011, 12:16 PM   #7 (permalink)
ZX - '97 ZX Monaco
OldContinents
90 day: 39.4 mpg (US)
There is also shiny aluminium? shades that are meant to put on windshield while car is parked. I think that it should be installed outside of the window to have proper effect as such would just warm air between window and shade if put inside. Ok, surely it does work inside too, but I think effect is not so great with it inside.
Best solution, install Kammback and park car so that sun does shine on rear part of car
Old 04-29-2011, 12:17 PM   #8 (permalink)
ZX - '97 ZX Monaco
OldContinents
I think that it would not be difficult to spray paint them?
Old 04-29-2011, 12:19 PM   #9 (permalink)
mcmancuso's Avatar
Louvers, yeah...
Old 04-29-2011, 12:45 PM   #10 (permalink)
aero guerrilla
Piwoslaw's Avatar
Diesel
That's exactly what I'd be willing to get. Maybe I'll just spraypaint them as jtbo suggested.
As for the shiny windshield block - I already have one, but it doesn't reduce thermal gain while driving, since it is folded and stowed then
Mcrews: Shades that hide inside the door liner is my ultimate goal
