Old 02-15-2015, 01:44 PM   #111 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Originally Posted by Old Tele man View Post
Surplus TANKS are available, but they are not very economical. However, they are "...built like a tank..." (pun intended).
As with every aspect of life, moderation is key. Do I want to drive a tank? no. Do I want to drive a plastic car with a 2 cylinder engine? no.
Old 02-15-2015, 01:58 PM   #112 (permalink)
herp derp Apprentice
Saturn-sold - '99 saturn sc1
Team Saturn
90 day: 28.28 mpg (US)
Yukon - '03 GMC Yukon Denali
90 day: 13.74 mpg (US)
This is making me think of.... http://youtu.be/z5Otla5157c
Ksa - I think I would enjoy driving a tank, and my plastic car has 4cyls
Old 02-15-2015, 02:35 PM   #113 (permalink)
IamIan -- for excellent use of the Ordered List.
Originally Posted by jcp123
As a classic car enthusiast, I have always hated that video...esp. As 59-60 batwing Chevys are a fav of mine, just behind Chevy's big bold 58s.
At least it was a 4-door. My preference, if I were a Chevy guy, it would be the '61 bubble-top coupe.
2000mc -- YOLO? To quote Apu Nahasapeemapetilon on The Simpsons, "Speak for yourself".
Old 02-15-2015, 05:43 PM   #114 (permalink)
IamIan's Avatar
Originally Posted by ksa8907 View Post
I disagree with your numbers, because it is not stated, any assumptions and extrapolations made cannot be taken as fact.
1 + 1 = 2
I don't need someone else to 'state' or tell me it's 2 .. I can do the math myself .. that is all that I did .. and I didn't even do any complex math either.
SUV death rates fall
From this article, "But drivers of today's SUVs are among the least likely to die in a crash, the Institute's latest calculations of driver death rates show. The change is due largely to the widespread availability of electronic stability control (ESC), which helps prevent rollovers. With the propensity to roll over reduced, SUVs are on balance safer than cars because their bigger size and weight provide greater protection in a crash."
Bold added.
You're comparing apples to oranges.
I did an analysis of the actual numbers of what actually happened in the real world .. my numbers did not exclude all the things they tell you they excluded in that paper you site .. I did not go out of my way to make a bias as that paper you sited did ... as shown bellow.
You're pointing to the odds of death (in the event of a crash) ... which can only relate to the number I posted ... IF
  1. Odds of getting in a crash are the same... they are not.
    Your own link bellow also directly refuets this .. in their own words:
    • "because they are more likely to get into situations that ESC is designed to prevent"
  2. Sample size of how many chances are the same... they are not.
  3. If all the exclusions they made .. they didn't make... but they did.
  4. etc ...
My wife and I are very good drivers. We allow plenty of following distance, obey the speed limit, and brake early.
Good
My primary concern is for the safety of my family. I want a vehicle that will protect us from all the other idiots out there. Simple physics, and the IIHS, show that larger vehicles are safer.
If that is your primary concern .. than take a bus .. they are safer per mile than personal vehicles (as previously sited) ... they are safer per trip than personal vehicles (as previously sited).
And even if you want to insist on the belief that larger and heavier is safer ... than the bus is both larger and heavier than any normal personal vehicle you could drive.
If that truly is your 'primary' concern ... than your course of action is clear.
The math I showed is even simpler than the physics ... and there are numerous simple physics arguments that can be made about the better overall safety of the lighter vehicle.
Here's the .pdf with more info and numbers http://www.iihs.org/externaldata/srdata/docs/sr4605.pdf
Read closer.
Not only is that still focusing on the 'in the event of a crash' ... with all the errors sited before about such a PoV.
But..
They also come right out and tell you some of the other choices they made ... that it doesn't take a genius to tell would change the results if they didn't do these things... these are all from your own link... in their own words.
  1. "The Institue computes driver-only death rates, because the presence of passengers varies."
    • Which is them coming out and tell you ... they ignored / didn't count any of the deaths of passengers ... easy to see the flaw in that approach.
  2. "A registered year is 1 vehicle registered for 1 year or 2 vehicles for 6 months each"
    • wow .. they come right out and tell you they intentionally count 2 vehicles as if they were only one ... hmm .. again not hard to see that could change the results.
  3. "Although the vehicles span 2005-08 models, only those equivalent to 2008 models are in-cluded"
    • They come out and tell you they are intentionally excluding vehicle data .. based on whatever standard they have chosen as "equivalent" ... hmmm ... again... not hard to see how that might alter the results.
  4. "In other words, if a vehicle was completely redesigned for the 2007 model year, the 2005-06 versions weren’t counted. The exception is the Malibu."
    • Wow .. the hits keep coming ... not only to they repeat their cherry picking of the data to crunch ... but they aren't even consistent with the method .. they just randomly make an exception for the Malibu ... again ... not hard to see this can effect the results.
  5. "Among 4-door midsize cars, for example, the lowest death rate was 19 for the Honda Accord, and the highest was 99 for the 2007 Chevrolet Malibu"
    • Sooo ... the exception they made before to include in 'cars' ... was the very worst of the cars ??? ... hmmm ... again ... not hard to see this kind of cherry picking can easily stack the deck for the results.
  6. "Death rates are adjusted with information on driver age and gender and vehicle density"
    and
    "Because the latest round of driver death rates has been finetuned in a way that previous ones weren’t"
    • Something wrong with just using the actual death rates number ... instead of adjusting them ? ... again ... not hard to see this can effect the results... and they even tell you this new adjustment is very different from their previous adjustments.
  7. "Although vehicle performance in the tests varied, the results didn’t correlate with insurance loss patterns"
    • They come out and tell you the real world loss patterns of insurance companies don't agree with their vehicle test results ... all the more reason to just use the real world death numbers I used previously.
Life Long Energy Efficiency Enthusiast
2000 Honda Insight - LiFePO4 PHEV - Solar
2020 Inmotion V11 PEV ~30miles/kwh
The Following 2 Users Say Thank You to IamIan For This Useful Post:
e*clipse (02-26-2015), oldtamiyaphile (02-15-2015)
Old 02-15-2015, 05:44 PM   #115 (permalink)
one of thOOOse people
twitchy - '98 honda civic dx + sir + ls
90 day: 30.2 mpg (US)
Norman - '14 Ford E-350 EXT
90 day: 16.18 mpg (US)
Silver - '12 VW Golf Base
90 day: 26.1 mpg (US)
Sparta - '19 Honda CB300R
90 day: 84.07 mpg (US)
I have said for years that if we replace all the airbags with steak knives there would never be any accidents. The drivers would all actually pay attention.
Come to think of it, I probably first heard that on this forum somewhere.
The Following 2 Users Say Thank You to hamsterpower For This Useful Post:
Fat Charlie (02-16-2015), Hersbird (02-16-2015)
Old 02-15-2015, 05:55 PM   #116 (permalink)
Just cruisin’ along
jcp123's Avatar
Beater Echo - '00 Toyota Echo
90 day: 42.67 mpg (US)
Hondizzle - '97 Honda Civic DX
90 day: 46.55 mpg (US)
Shaggin Waggin - '14 Chrysler Town + Country
90 day: 22.56 mpg (US)
There is some truth to that. It's why I handwrite things or use a typewriter...much easier to pay attention the first time than to start over or try and correct afterwards.
'97 Honda Civic DX Coupe 5MT - dead 2/23
'00 Echo - dead 2/17
'14 Chrysler Town + Country - My DD, for now
'67 Mustang Convertible - gone 1/17
Old 02-16-2015, 12:45 AM   #117 (permalink)
Dark Egg - '12 VW Touraeg
As far as saving lives, aren't we constantly barraged with how bad the population growth is? Then we also go about curing diseases, eating healthy, and exercising. reminds me of this...
Health nuts are going to feel stupid someday, lying in hospitals dying of nothing.-Redd Foxx
I am starting to feel we need a better method of natural selection, like less safety on cars. My other idea is to release 160 pound Canadian Grey Wolves back to their natural range in Central Park. Hey, New Yorkers seemed to think we needed them introduced here in Montana. Notice I said introduced not reintroduced as these are not the Wolves my great grandfather had to deal with.
Old 02-16-2015, 07:44 AM   #118 (permalink)
nemo's Avatar
Chief - '06 Pontiac Grand Prix
90 day: 26.7 mpg (US)
SF1 - '12 Ford Fiesta S
90 day: 30.95 mpg (US)
Not enough predators in NYC?
Old 02-16-2015, 08:43 AM   #119 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
I've been in a tank. 60 tons on tracks make for a smooooth ride, but a sudden stop (like you'll get from hitting another tank) will make your next of kin wish you'd been riding in something with crumple zones. That energy's got to go somewhere, folks.
It was nice to see the IIHS explaining that armor makes you stupid:
“We think most of the differences HLDI found in ESC effectiveness reflect things like how a vehicle handles, its size and weight, and who’s at the wheel more than they do the system’s design or manufacturer. That is, the SUVs with the highest insurance losses to begin with get the biggest benefit from ESC, not because they have better stability control systems but because they are more likely to get into situations that ESC is designed to prevent.”
In other words, If you make something idiot proof, nature makes a better idiot. It's not just a joke. If we can step back from that report being a study of how to idiot proof these things, we can see that the solution is right there- size, weight and handling keep people out of accidents more than electronic band-aids ever will.
Just the one in the steering wheel. That's all we really need.
Transmission type Efficiency
Old 02-16-2015, 10:10 AM   #120 (permalink)
"But your Honor my car was SUPPOSED to avoid the collision, while I was sleeping." I hope I don't live THAT long.
regards
mech
