Old 05-29-2009, 11:04 AM   #11 (permalink)
Same effect as most HAI. It reduces the amount of power you have and therefor automatically makes you drive more eco friendly just because. . .well you can't do anything else.
It's like bob said, if you stick a really big block of wood under your gas pedal its just as eco friendly. It keeps you from using fuel. Does not in anyway actaully improve efficiency just reduces driver waste at best. The gains will be minimal if anything because you are inducing extra restriction and therefore pumping losses on the engine.
Old 05-29-2009, 01:55 PM   #12 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Originally Posted by markweatherill View Post
My question would be: clockwise or anti-clockwise, which is better?
Maybe they're like toilets- the direction of the swirl depends on which side of the equator you're on??? So I suppose they have special Aussie versions.
Old 05-29-2009, 02:30 PM   #13 (permalink)
lol Frank thats a myth. The swirl direction comes from the suction pattern and the flow pattern.
If you take a pump and drain water out the bottom of a barrell and inject the water back in at the top the direction of swirl is determined by(if the pump has a face, that) the direction the water is added. If you notice water pours into the bowl itself in one direction usually Also the water coming through that wide mouth hole at the bottom front of the bowl is swirling in that direction as well.
Toilets that don't swirl at all(large powerful commercial toilets) suck water straight down no vortex whatsoever. I worked at a summer camp and we got sick of pumping toilets daily so we got the massive suction versions. They don't swirl at all and you had best standback. .
Old 05-29-2009, 02:34 PM   #14 (permalink)
wdb
lurker's apprentice
Scootie - '08 Fit Sport
90 day: 37.19 mpg (US)
No silly, it has to do with whether the car is right-hand drive or left-hand drive. Duh.
Old 05-29-2009, 11:05 PM   #15 (permalink)
I like those toilets that make you hang onto the rails to avoid being sucked in. They're the only ones that can handle what I leave in them in one shot!
I know that's disgusting, but I couldn't resist.
Old 05-30-2009, 09:30 AM   #16 (permalink)
Interested Newbie
Katana's Avatar
Silver Citroen Saxo - '02 Saxo 1.4i Furio
Those tornado things look like a shrapnel accident waiting to happen.
Crooked toothed, tea swilling crumpet eater!
Old 05-30-2009, 02:03 PM   #17 (permalink)
scam
No science-talk here,but even if the restriction in the intake did not INCREASE pumping-losses,would not any of this "beneficial turbulence" be nullified as soon as the air passed through the throttle-body or carburetor throttle-plate.And in a carbureted engine,which can have significant droplets of fuel present in the charge,would not the centrifugal force of a vortex not behave as a cyclone-precipitator,slinging the fuel to the walls of the intake runners,wetting out the walls? I'm given to understand that turbulence can be great for induction however,"vorticity" is a completely different animal.
Old 05-30-2009, 05:08 PM   #18 (permalink)
lol aero,
I just assumed it had to go in after the throttle otherwise it would be pointless.
Yeah apparently whoever thought of this had not heard of a lab centrifuge -_-
increase, intake, money, mpg, scam
The Ethanol Scam: Are ethanol advocates giving slanted mpg numbers? Ptero Fossil Fuel Free 15 04-22-2010 10:58 AM
Ethos FR Snake Oil Or The Real Deal? Greenblazer General Efficiency Discussion 21 09-26-2008 05:36 PM
Home Depot Scam!!! ajax_6531 The Lounge 16 07-05-2008 06:34 PM
Newbee with hydrogen kit mechanic999 EcoModding Central 20 05-27-2008 03:17 AM
Scam or not?? Taco Bowl EcoModding Central 3 04-30-2008 12:48 AM
