Old 05-28-2010, 01:39 PM   #1 (permalink)
THE DODGE - '06 Ram 2500 ST
90 day: 22.64 mpg (US)
The Saturn - '08 Vue XR
90 day: 21.94 mpg (US)
The Odyssey Van - '011 Odyssey EX-L
90 day: 29.1 mpg (US)
Dodge turbo diesel programmer/FE tuning questions?
I have a Smarty S06 POD programmer with REVO for my truck. It has tunes in it ranging from half stock power to +170whp over stock plus ability to run 1-100% of any tunes power. It also has the ability to adjust timing, fuel rail pressure, torque management, wastegate on/off, tire size adjustment, and 25-250mph adjustable speed limiter. Should lowering the power output causing it to be under more load be more fuel efficient? Testing now running +30whp tune and 25% power output. So far have noticed higher load on motor, no smoke, slower boost climb, and less overall boost. Will see how this helps/hurts mpg but curious on what in theory it should do.
The Following User Says Thank You to nubbzcummins For This Useful Post:
elhigh (05-28-2010)
Old 05-28-2010, 04:47 PM   #2 (permalink)
Slow and easy
elhigh's Avatar
Josie - '87 Pickup
90 day: 30 mpg (US)
Hi,
Thanks for doing this; I keep seeing mag articles and ads that loudly proclaim both power and mileage boosts, it just sounds too much like the holy grail. I'd like to hear what's up from an honestly curious skeptic.
You're not in front of me...
I'm 25,000 miles in front of you.
Old 05-28-2010, 09:26 PM   #3 (permalink)
More power and fuel efficiency can be obtained under the right conditions however those conditions will be different with each tune, vehicle, driver, weather condition, ect.....
Old 05-30-2010, 10:34 AM   #4 (permalink)
Porno Music Producer
zhillz's Avatar
lolwut - '98 Civic EX
90 day: 47.5 mpg (US)
I know in cars that people add turbos to or increase turbo psi, they need REAL tunes and the programmers aren't safe. But i have always herd the opposite for diesel trucks, so I'm in for the answer.
Old 06-05-2010, 09:56 PM   #5 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
Lets see.
6 speed ALH TDI
Old 06-08-2010, 08:25 AM   #6 (permalink)
99metro's Avatar
putt-putt - '99 Metro Base
90 day: 58.76 mpg (US)
Dusty - '89 Bronco XLT
90 day: 13.89 mpg (US)
Cowboy - '90 Bronco XLT
90 day: 17.42 mpg (US)
HayHauler - '06 3500 ST
90 day: 18.03 mpg (US)
Keep your boost as low as possible and your EGT as low as possible. My buddy has a Smarty and loves it. Not too many people out there hypermiling their full-size diesels.
Once my '03 6.0 gets out of the shop, I'm trading it in for a 5.9 24v. Got my eye on an '06 quad cab long bed 4x4 2500 SLT with a manual tranny.
2006 3500 Dodge QC/FB 5.9 handshaker
Old 06-10-2010, 11:55 PM   #7 (permalink)
Ok.....running 25% power did not help any however running the +30hp tune with timing, more fuel rail pressure, lowest torque management setting, and wastegate off is looking good. Just did 23.69mpg with very inconsistent and varied driving techniques/styles implemented along with unfavorable driving conditions. I feel that I can do better with this same tune and may try the 1/2 power tune to see how it does. Time will tell.....
Old 06-13-2010, 09:37 PM   #8 (permalink)
2004 CTD - '04 RAM 2500 SLT
90 day: 21.37 mpg (US)
There was a few of us got round and round on the subject of tuners on a CTD:
http://www.dieseltruckresource.com/d...g-t264698.html
2004.0 7,360-lb DODGE Ram QC/LB 2500 2WD/6-speed Cummins 305/555 ISB. Stock, except LEER bed topper and twin muffler exhaust. 180,000 miles at 4,625-hrs @ 39 mph. 15-cpm solo, 25-cpm towing. (22-mpg avg past 37k)
Fuel Log
Old 06-18-2010, 10:58 PM   #9 (permalink)
The "stock" tune in my truck gives me less mpg than the current +30hp smarty tune I am running in "nearly" the same driving conditions so..........? "Stock" as in factory tune and the "Stock" tune in the smarty programmer are both lower in mpg along the lines of 1-2mpg difference..........?
New here with 2006 Dodge Ram 2500 Turbo Diesel nubbzcummins Introductions 3 09-02-2010 01:35 AM
ScanGauge Questions for a VW Diesel. Deezler Instrumentation 13 07-09-2010 07:42 PM
Spark ignition Diesel engine, AKA your car mechman600 EcoModding Central 27 06-07-2010 07:49 PM
Suzuki vitara 5 door turbo diesel 1997. ted frater Success Stories 0 04-10-2010 09:50 AM
Very Rare Chevy Blazer Turbo Diesel - SVO Conversion eco_generator For Sale 3 10-12-2009 09:38 PM
