Old 01-05-2017, 03:50 PM   #1 (permalink)
Does air in radiator increase warm up time?
I'm hearing splashing in my dashboard like heater core is clogged but it is not. Just wondering if I can burp the air out, will it heat up faster in the morning?
Old 01-05-2017, 04:24 PM   #2 (permalink)
Probably means the cooling system is very low.
Old 01-05-2017, 09:55 PM   #3 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
You might wanna get that figured out before you low your head gasket or something. Air in it, or running low on coolant...neither is a good thing.
The Following User Says Thank You to Stubby79 For This Useful Post:
Xist (01-08-2017)
Old 01-05-2017, 10:29 PM   #4 (permalink)
Checked fluid level.
It was below the low mark. I topped it off and will see how it does tomorrow. Hoping it was just air trapped in it.
Old 01-08-2017, 03:05 PM   #5 (permalink)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 57.64 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 26.68 mpg (US)
Don't check just the overflow tank (the plastic container), but also check the radiator level. It should be to the very top. Check it cold so you don't burn yourself, and the water level is at its lowest.
Xist (01-08-2017)
Old 01-09-2017, 03:36 AM   #6 (permalink)
Did you just replace the heater hoses? The heater will make this noise if the hoses are reversed.
Old 02-14-2017, 05:07 PM   #7 (permalink)
ScanGauge <3
ThermionicScott's Avatar
There are other reasons to hear water sloshing around near the dash, trapped rainwater in the climate control system being a possibility.
Best tank (so far): 32 MPG
Old 03-28-2017, 01:58 PM   #8 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
If anything, air in the cooling system DECREASES warm up time. I got air in my cooling system back when I put a short ram intake on my 4 cylinder accord and it would be up to temperature about a mile earlier than normal. Then it kept climbing...
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
