I have used PTFE in engines before.
The one where I used it the most was my 6.5L diesel engine build.
I sparyed the main and rod bearing shells with a light coat of remington dry PTFE spary, then put a fairly thick coat on the injector pump driver gear and used a PTFE and wax "dry chain" lub on the timing chain.
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
