Old 06-20-2011, 11:00 PM   #1 (permalink)
larrybuck's Avatar
Location: sw Washington (state), a little north of Vancouver
Does anyone use a Slick additive to oil?
I have literally used Slick 50 in a '92 Dakota I bought new to use as a 300+ile a day/5 days a week courier vehicle. I think it helped a lot, but it wasn't cheap enough to overuse!
If I remember right, I think I REFRESHED about every 3 months or so.
Do any of you have a helping tradition like this toward your rides?
About 3-4 yrs. ago, a friend turned me to Molybdenum disulfide which is in a powder (super fine 1.5 microns) I buy it in a plastic bag inside of a sealed 1# mini plastic bucket.
I use about a teaspoon an oil change. For 1 veh., this should last a few yrs. for under $50.00.
I just pour my teaspoon into a plastic cup, and little by little I add the fresh oil, and stir, pour into eng., repeat, and repeat. You can feel how slick this stuff is! A little goes a long ways!
The same friend said I could use same in manual trans/diff./and even wheel bearings, but I haven't been brave enough to try that yet!
The thing that I hope that its working the best at; is the dreaded COLD START engine wear! I feel like it has worked well in my '87 CRX.
If interested, this can be ordered from Rose Mill Co. - chemicals lubricants processing.
They are located at E. Hartford, CT.
WARNING!!!!...........For those you do not know; don't put this in your motorcycle/scooter, because the same oil is shared w the trans., and the loss of NEEDED friction will cause you to SLIP!
Old 06-20-2011, 11:38 PM   #2 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
I was actually a distributor for Slick 50 more than 25 yrs ago. It was sold by a company called Petrolon I believe. I have used it in every car I have ever owned. I don't try to make any claims. But my parents ran their buick century out of oil (after I moved away). They had it towed, then oil put in and it kept going.
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 06-21-2011, 11:09 AM   #3 (permalink)
UFO
UFO's Avatar
Beetle - '01 Beetle GLS
90 day: 42.61 mpg (US)
4x4 - '89 Pickup DLX
90 day: 30.36 mpg (US)
Absolutely not.
"We think B20 is for suckers" N. Cowell, Denver B100
"Climate change denial is a conclusion in search of a rationalization" labman57
Old 06-21-2011, 01:50 PM   #4 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...if it ain't already *in* the oil from the factory, it don't need to be added!
...years ago, the U.S.Army Automotive-Tank Command tried such additives and deemed they were not worth the added co$t and effort...since I participanted in those tests ('72-'82 at Yuma Proving Grounds) I've never used them personally.
Old 06-21-2011, 02:12 PM   #5 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
No. Oil has cleaners and additives in it already. Choose a decent make, and the appropriate grade (or better if possible) and change it regularly.
Didn't whoever invented PTFE say something like it was never meant to be used inside a car engine ?
EDIT - A non return oil filter will help with cold starts as it prevents oil from draining back to the sump when the engine is stopped. And second edit is oils like Magnatec (claim to) stay in the engine when it is stopped so it is lubricating when it starts again.
If you are leaving an engine for a loooooong time then I would crank it before starting maybe with the coil disconnected.
No longer here. Bye, and good luck to all.
Old 06-21-2011, 10:48 PM   #6 (permalink)
mwebb's Avatar
1996 geo metro - '96 metro base
no
every OEM specifically and adamantly does not approve any additives to be installed in their recommended OR
Mandated for warranty purposes oil .
do you think there may be a reason for that ?
study and learn at
BITOG , Bob is the oil guy , forums
Old 06-22-2011, 01:00 AM   #7 (permalink)
mcrews's Avatar
study and learn at
WOW.......what a relief to have your expert opinion.
Guess that when the QUAKER STATE (that is a pretty popular brand of oil sold at walmart) has a HIGH MILEAGE product that says with SLICK 50.........
must be some chicken shxx bs that is sold black market to walmart.......
heck......it's probaly some uotlaw off-shore company.........
THe oil used in this analysis is the High Mileage Quaker state w/ slick 50.
AND HAVE BEEN USING SINCE 80k.
ECO MODS PERFORMED:
First, Grille Block
Old 06-22-2011, 03:19 PM   #8 (permalink)
UFO
UFO's Avatar
Well there you go. Older engines can tolerate more crud in the oil because the clearances are worn. I'd like to see Quaker State warrant your engine. And just because Quaker State is taking money from Slick50, it must be ok in your engine? Sounds like a conflict of interest NOT in your favor.
Never in my cars, never.
Old 06-22-2011, 07:21 PM   #9 (permalink)
...means EXACTLY that QS figured they could sell oil to people if they had that label on it. Nothing more, nothing less. It says absolutely nothing at all about the effectiveness of the oil; it just says that they think they can charge money for it.
And judging by the popularity of Slick-50 as a stand-alone additive, I think they were quite right.
I won't put it in any of my cars.
-soD
Old 06-23-2011, 02:38 PM   #10 (permalink)
mcrews's Avatar
wow.
no really, wow.
Do either of you actually read what you write??
"Never in my cars, never"
really?
two thoughts........
1. If I gave you a million dollars you would. Or your just ..........
2. Maybe Chalton Heston can pull off the "have to pry it out of my cold hand" attitude to the NRA, but that is a little 'over dramatic' for a little forum......
ECO MODS PERFORMED:
First, Grille Block
