Old 12-01-2011, 01:24 PM   #61 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Thats not true at all. The 3rd gen Prius uses external EGR with a cooler to run up to 30% EGR mixtures. If they could get better mileage with internal EGR I'm sure they would have.
The Mazda Skyactiv engines also use cooled external EGR.
Old 12-02-2011, 02:04 AM   #62 (permalink)
So besides the computer control and EGR cooling, what has changed with EGR systems over the years to make it how it is today?
And perhaps more important, would it be possible to retrofit older vehicles with newer EGR technology to improve performance in any way?
Old 12-02-2011, 07:44 AM   #63 (permalink)
CM400E - '81 CM400E
That was one of the things I wanted to play with on my Paseo. Alas I haven't had time to actually do it yet.
Here is the thread on it: Increasing EGR flow for better mileage
Old 12-03-2011, 12:38 AM   #64 (permalink)
V8 guy
Sub - '84 Suburban C10
Pickups
camaro - '85 Camaro Z28
EGR in diesels hurts fuel economy.
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
Old 12-03-2011, 06:37 AM   #65 (permalink)
Eco-ventor
Princess - '92 MX-3 GS
House of Tudor
90 day: 33.52 mpg (US)
Send a message via MSN to jakobnev
I suspect that having a much larger engine at lower BMEP to keep NOx down would be much worse for fuel economy tho.
Remember, even if you win the rat race - you're still a rat.
2010: 454.92L for 5313.90km => 8.56L/100km (27.5MPG US) (5 months)
2011: 606.11L for 7754.04km => 7.82L/100km (30.1MPG US) (Full year)
2012: 170.10L for 2405.00km => 7.07L/100km (33.3MPG US) (In progress)
Old 12-03-2011, 01:29 PM   #66 (permalink)
Yeah, theres really no point to EGR other than reducing NOx emissions. If manufacturers were allowed to use lean burn in production engines you would never see EGR.
Old 12-03-2011, 04:08 PM   #67 (permalink)
EV Wannabe
The Booger - '92 MX-3
90 day: 23.86 mpg (US)
It depends on the application. I build EGR deletes for 15L Cummins ISX engines. My customers that haul lighter loads and/or stay in the city tend to get a small increase in mileage, maybe 15% or so. The real gain is the elimination of the notoriously unreliable EGR valve that plagues these particular engines and the need to replace them every 2 years at a cost of around $1000. My customers with very heavy loads, Super-B Trains at 140,000 lbs in the mountain highways, tend to lose mileage by about 15%. I do not sell them to these guys anymore because they are never happy with the results.
In a pickup or VW TDI where overall load is very light, there will definitely be an improvement with an EGR delete.
Old 12-03-2011, 05:25 PM   #68 (permalink)
I don't see how the heavy load diesels get worse MPG after an EGR delete as the EGR valve will be closed anyway due to the load.
Is your delete option just a resisitor mod to drop the MAF reading when the valve should be in operation?
Old 12-03-2011, 05:27 PM   #69 (permalink)
Not quite correct. An open EGR valve reduces pumping losses due to the restriction caused by the throttle flap, without allowing any more oxygen into the cylinders.
Old 12-03-2011, 06:36 PM   #70 (permalink)
EV Wannabe
No, it is a full block off plate. The EGR motor and position sensor remain intact to keep the ECM happy, but they are not connected to anything. I send a modified signal to the delta-P sensor to make the ECM think EGR is flowing when it wants some.
It doesn't make sense to me either, but data from three heavy haul trucks is what I am going by.
Increasing EGR flow for better mileage Daox EcoModding Central 201 Yesterday 08:07 PM
Trouble Code PO401 EGR Flow Insufficient Detected Ford Man Off-Topic Tech 4 12-09-2011 12:45 PM
Metro EGR passage cleanout needed -- any tips? lyd DIY / How-to 2 09-30-2008 11:11 PM
EGR dilution for more MPG? cfg83 EcoModding Central 18 04-29-2008 09:11 PM
Adjustable EGR guitarterry EcoModding Central 1 04-27-2008 03:04 PM
