Old 05-18-2010, 12:34 AM   #1 (permalink)
30.67 MPG
carbonaltima's Avatar
Does an egr help that much?
How much does an egr valve help in improving fuel economy?
30 MPG is the FE equivalent of a 13 second 1/4 mile.
Old 05-18-2010, 07:27 AM   #2 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
EGR alllows higher compression, more advanced timing, and a slight reduction in the fuel necessary for every combustion event. Properly applied it may have even greater benefits in the future, but they are significant today, and in the early years of EGR (late 60s) many tried to disable the EGR and found the engines would hardly run.
regards
Mech
Old 05-18-2010, 11:33 AM   #3 (permalink)
Even Todays Vehicles will hardly run if you "try" to disable it.. However if you say learn the routing of the vacuum lines (thanks alldatapro ) Then you can disable it as well as make the car run as normal because it runs poorly because it's technically a vacuum leak depending on how you try to disable. Not sure if any of this makes since to anyone else but hey a new born will do that too ya "lack of sleep and sanity" lol.
Trevor
Old 05-18-2010, 11:44 AM   #4 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Well, I think the most extreme case I know of is the gen 3 prius. It runs up to a 30% EGR mix. I'd imagine on that engine not having EGR would be a huge detriment. On any other vehicle who knows. It all depends on the design of the engine.
I started a thread a while back about using more EGR to create a lean burn like effect. I haven't ever had the chance to test it though.
Old 05-18-2010, 12:34 PM   #5 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
I've tried mine disconnected and connected and could never tell the difference one way or the other. Heck the computer doesn't even seem to be able to tell the difference, it doesn't give a code with it disconnected. So I just leave it disconnected because I've heard it helps keep carbon from fouling up the intake that way.
But I would think newer cars are more sensitive that way and EGR could make a real difference.
Winter daily driver, parked most days right now
Summer daily driver
Old 05-18-2010, 02:21 PM   #6 (permalink)
I'm not sure i know new new cars are much more sensitive to it then the older one that basically just run off vacuum because of increasing emissions like the new bmw has egr like a normal then they're also starting to use it for thermal energy from the exhaust gas to make electricity before it puts it back in the motor. the newer they get the harder it's gonna get to modding for efficiency, power, or anything else without a doctorate in nuclear thingamijigee lol. But hey hopefully we'll start flying our cars too.
Old 05-18-2010, 08:29 PM   #7 (permalink)
A little hard to say with certainty.
In my car (3.8 GM with 4L60E trans) the EGR operates only on when the cruise control is operating and when that happens the "Lean run" cycle also kicks in.
How much is due to EGR and how much to "lean run" is unknown.
In any case it all happens inside a black box somewhere and my control over it is nil.
Running on cruise means a reduction of about 10% to 15% in fuel numbers on average over my normal driving style.
Peter.
Old 05-18-2010, 10:52 PM   #8 (permalink)
I have to start over?
Big inefficient truck - '94 Ram 2500
90 day: 12.1 mpg (US)
Honda Civic - '84 Civic DX Hatchback
Well, by the time we make hovercars, we won't have to worry about gas because the antimatter charge that makes the cars levitate will also push them forward
Old 05-19-2010, 02:41 PM   #9 (permalink)
Phantom's Avatar
Bonnie - '98 Bonneville SSE
3800
90 day: 26.91 mpg (US)
I know on most US 1993-2003 GM 3.8 V6s (3800) the EGR being disabled will drop cruising by 1-4MPGs. Deleting it is easy also remove the bolt holding the EGR pipe to the Lower Intake Manifold block the hole with something (tap and plug) do the same to the other end of the pipe and unplug the electrical connector, then ignore the check engine light.
I move at the speed of awesome.
Old 05-20-2010, 01:03 AM   #10 (permalink)
mwebb's Avatar
1996 geo metro - '96 metro base
EGR is good for everything - do not delete it
somehow this subject keeps being reposted
somebody gets it in their mind that removing the EGR system helps the engine run better and somehow magically increases power output and improves fuel economy
all of that is pure blarney -
EGR does not function at idle or WOT - and does not affect maximum power output .
EGR does function at part load or cruise .
the Primary function of EGR is to add INert exhaust gases to combustion to reduce combustion temperature and by so doing
reduce the formation of the pollutant NOX
EGR improves fuel economy by reducing suction throttling loss and reducing engine compression and reducing engine displacement
BY DILUTING THE AIR FUEL MIXTURE IN THE COMBUSTION CHAMBER WITH INERT EXHAUST GASES
while it is active
deleting EGR is going to cause your system to pollute more and it will reduce FE , deleting EGR will have no affect on maximum power available.
and on a 1996 or newer car ;
doing anything to interfere with EGR function is "tampering " with the OBD2 system and a violation of federal law .
bottom line ;
if you do not know EGR theory ....
do not frak with your EGR unless you need to clean out the passages to IMPROVE / INCREASE EGR flow .
The Following 3 Users Say Thank You to mwebb For This Useful Post:
Christ (05-20-2010), ShadeTreeMech (05-22-2010), TEiN (05-20-2010)
Increasing EGR flow for better mileage Daox EcoModding Central 201 Yesterday 08:07 PM
Trouble Code PO401 EGR Flow Insufficient Detected Ford Man Off-Topic Tech 4 12-09-2011 12:45 PM
Metro EGR passage cleanout needed -- any tips? lyd DIY / How-to 2 09-30-2008 11:11 PM
EGR dilution for more MPG? cfg83 EcoModding Central 18 04-29-2008 09:11 PM
Adjustable EGR guitarterry EcoModding Central 1 04-27-2008 03:04 PM
