Old 07-12-2009, 08:29 AM   #11 (permalink)
Renaissance Man
Formula413's Avatar
Sleepwalker - '97 Firebird Formula
90 day: 20.04 mpg (US)
Spock - '92 VN750 Vulcan
90 day: 49.39 mpg (US)
03MX - '03 Civic Hybrid
90 day: 49.04 mpg (US)
My question is does exhaust noise attract hot babes looking for action? Many seem to think so.
I am doing some long term testing of this theory in my Firebird.
When this has been discussed before I think the consensus was that freer flowing mufflers will only produce performance gains but not FE gains, since driving for FE generally involves using light throttle, and the increased airflow available from a performance muffler is not providing any benefit with the small amount of exhaust gas being generated. The best thing you can do with the exhaust for FE is optimizing the diameter of the pipe for the power being produced IMO. Too large a pipe will hurt velocity.
More choices...
Old 07-12-2009, 11:11 AM   #12 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
bwaa ha ha hyuk hyuk hyuk
Old 07-12-2009, 04:37 PM   #13 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Exhaust Basics
I had the same questions with respect to exhaust, flow, and FE.
The best rule of thumb to use: "Stock is Best". It was finely tuned by experts -- any change in that system will effect the bottom line. Quiet is good.
Here are some great links on the Science and myths of Exhaust, by Team-Integra.net:
Exhaust Basics
Advanced Exhaust Tech I
Advanced Exhaust Tech II
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 07-12-2009, 09:08 PM   #14 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
I've heard conflicting things over the years. If no ECU modifications are made, will a car get better FE with reduced exhaust backpressure? Is backpressure ever desirable?
Old 07-12-2009, 09:21 PM   #15 (permalink)
Renaissance Man
Formula413's Avatar
My understanding is that no, it is not. I read an article once about someone who put a butterfly valve into an exhaust pipe and set out to determine what was an optimal amount of back pressure for different engine loads, with the goal of using the butterfly to create the right amount of backpressure. Turns out that no extra backpressure was helpful at any engine load.
Another theory I heard was that an exhaust pipe that is too large in diameter for the application will actually allow atmospheric pressure to work against the engine. I have no idea if this is true or not.
More choices...
Old 07-12-2009, 09:25 PM   #16 (permalink)
RH77,
thanks for the links to the articles.
They are a real find.
Cheers , Pete.
Old 07-12-2009, 09:47 PM   #17 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Yes, it is. The exhaust must combat atmospheric pressure to exit the pipe. When it comes out of the engine, it's obviously under more than atmospheric pressure. As it goes through the exhaust, it slows, cools, and loses pressure.
While back pressure is absolutely not necessary, under any circumstances, exhaust diameter and length are necessarily tuned for optimum specifications.
I can't remember the formulae, or where I wrote them down, but there are some equations that will let you determine the optimum size/length of pipe based on VE (or a number representing exhaust flow as volume).
You basically want to fill the pipe, but not create more pressure than what is coming from the engine's exhaust pulse. You want the exhaust gasses to stay hot as possible, for as long as possible, so they're forced to exit the pipe as quickly as possible, which creates a scavenging pulse at the valve, helping to suck in more air, or reduce pumping losses.
I once tried the backpressure thing, but for a different reason: I was attempting to make an auto-tuning exhaust.
I originally theorized, that based on engine vacuum (which approximates load) a vacuum solenoid could open/close a section of the exhaust pipe just after the manifold collector to effectively "tune" the end of the manifold. No muffler or pipe was used after the collector, and the whole system failed to work as I determined it should, so I never bothered to try to dyno tune it.
I might still work on it some after I get rid of a few projects.
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
Fuel Economy related papers tasdrouille General Efficiency Discussion 33 03-06-2012 12:22 PM
mileage computer for a carbureted engine diesel_john Instrumentation 162 07-18-2010 05:31 PM
smart cdi (diesel) owner from BC, Canada smartzuuk Introductions 23 04-10-2010 12:22 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
