Old 12-13-2008, 01:08 PM   #1 (permalink)
'01 Jeep Cherokee - '01 Cherokee
90 day: 16.65 mpg (US)
Does the Heater Waste Gas?
This is a discussion that I had with a coworker a while back. He has a mechanical engineering degree so he should be quite knowledgeable and have a fair bit of common sense and intuition.
The question is weather or not having the heater on burns more fuel. His answer was flat out "no", that it is waste heat and would be lost anyway.
My assessment was that during engine warm up, having the heater turned on would prolong the amount of time that the engine is below operating temperature and therefore increase fuel consumption. Once operating temperature is reached I agree with him that there is no loss in efficiency.
Does anyone here have any insight into this? Thanks.
Old 12-13-2008, 01:38 PM   #2 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
You are exactly right.
And its not only the cooler temperature that reduces efficiency, it takes more of a hit. When below a certain temperature, the car's computer often runs in warmup mode. Which defaults to a richer fuel mixture, and the torque converter does not lock up on an automatic transmission.
I am a mechanical engineer too, and some of my coworkers who have more seniority still dont know jack about cars. Its a different field in a lot of ways.
Winter daily driver, parked most days right now
Summer daily driver
Old 12-13-2008, 01:50 PM   #3 (permalink)
ECO-Evolution
Lazarus's Avatar
Iron Horse - '97 Intrepid
C-3 - '08 XF50X
90 day: 135.32 mpg (US)
The heat has to come from somewhere. I see about 8 degrees different in the water temperature when running the Heater. One of the reasons to run a grill block, beside aero, is to help warm up quicker and run hotter. The hotter the engine, to a point, the better the FE.
The Old beaters I drive when it starts to overheat I can turn the Heater on Full blast and the temp will drop.
"Judge a person by their questions rather than their answers."
Old 12-15-2008, 02:15 PM   #4 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
if I don't turn my heater fan down when at a stop, I can move my engine temp needle down a fair amount, I tend to keep the fan on the lowest setting or my car will never register on the temp gauge before I get to work, and if it's not warming up it's using more gas.
Old 12-15-2008, 03:45 PM   #5 (permalink)
I sure wouldn't call is waste, I like to stay warm, but during a long car ride my girlfriend asked me the same question, does it use more gas? I had some time to think about it... there are two other very small power consumers to consider:
A stretch, but the fan you use to get that heat into the cabin takes electrical power, requiring the alternator to work a little harder.
A real stretch, the waterpump works harder to push the coolant through another heat exchanger, increasing the surface area in which the coolant must flow over.
Again, these are both big stretches, and small consumers of ultimately slightly more fuel when you run your car's heater.
Old 12-15-2008, 04:35 PM   #6 (permalink)
dichotomous's Avatar
CivySi - '03 civic SI
90 day: 31.99 mpg (US)
I think your engineer friend was refering to when the car was already up to operating temperature. in that case, its very unlikely that the heat itself will cost you power, the blower fan will.
if you wait untill your car is up to temperature then turn on the heat you can have your heat and drive it too, so to speak. once the car is up to operating temps (NOT warmup, NOT extending warmup, already warmed up) then the extra heat IS just waste heat that would only heat the radiator.
btw the radiator is not ALWAYS flowing engine coolant, there is only flow when the coolant is above the preset temperature control (usually a wax that melts at a specific temperature) valve and allows the flow to go through the radiator, its a paralell line on the coolant circuit.
though I belive many cars use the engine oil to heat the car, or used to at least
Old 12-15-2008, 05:04 PM   #7 (permalink)
Thanks for the replies, you all bring up some interesting points. I know from my ScanGauge II that my engine consumes over 2.0gph at idle when cold and around 0.7gph when hot, so there is a significant difference.
Old 12-15-2008, 06:03 PM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
I'm sure it wastes fuel because now everyone idles their car for a half hour before driving anywhere.
But that behavior aside, and warmup time aside, it is just waste heat once the engine is up to temperature.
Old 12-15-2008, 06:26 PM   #9 (permalink)
papa smurf - '81 pickup 4wd dlx long bed 1/2 ton
90 day: 17.6 mpg (US)
Heep - '011 Grand cherokee Larado x 4x4
90 day: 19.92 mpg (US)
Old toy - '81 Cm400e
Da bike - '06 Shadow Vlx deluxe
90 day: 50.18 mpg (US)
yeah i leave my heater off till it gets to 170ish, stops at 182ish
but with the heater blowing at full, it does take alot longer to warm up. thus useing more fuel.
but once warm nah.
2 gph at start up wow.....
2011 Jeep grandcherokee larado x v6 4x4. (wifes/weekender)
98 taco base 4x4 i4 toyota bought back due to a rust spot. gone but not forgotten.
81 toyota 4wd long bed 1/2 ton
Old 12-15-2008, 07:02 PM   #10 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
None that I've ever heard of.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Pick Your Poison - Whose gas to buy? SVOboy General Efficiency Discussion 84 11-22-2010 10:19 PM
How do you eco-drive a diesel ? groar Hypermiling / EcoDriver's Ed 105 04-03-2010 08:25 PM
Geo Metro Block Heater How-to bbjsw10 DIY / How-to 75 12-31-2009 12:34 AM
What's your best bet for an automatic? Crono EcoModding Central 16 10-22-2008 01:14 PM
