Old 01-17-2012, 05:23 PM   #1 (permalink)
does siamese motors+dual controllers=cheap speed?
If I sourced two identical forklift motors (8" or 9", one with twin shafts, siamesed via a coupler. Then ran each with separate motor controllers (OpenRevolt) and seperate 144V battery packs, direct drive to 4.11 gears in a featherweight Datsun PU.
Figure I could get that done for about $4k plus my time for fabrication, and saving up for batteries when the day comes.
Is there a more budget friendly recipe? 11"-13" forklift motors? Is there a bigger OpenRevolt controller in the works?
Looking for 6 second runs to 60, 70 mph top speed, and a 40 mile radius.
Old 01-17-2012, 05:31 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I believe Paul is working on a 1000A version of the OpenRevolt controller. In fact I think Ben Nelson may have recently toasted the test controller.
Old 01-17-2012, 06:11 PM   #3 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
I don't see any flaws in this idea as to why it wouldn't work.
Even if you get a 1000amp open revolt controller, you can still do this with the motors and if you can find a relay large enough to handle the amps you could even switch from parallel to series and have a high/low affect.
Old 01-17-2012, 10:02 PM   #4 (permalink)
PaulH
MPaulHolmes's Avatar
Michael's Electric Beetle - '71 Superbeetle 500000
haha. Yes, I figured out the problem too! At least I think I figured it out. Next attempt to be completed in the next couple weeks. And if that blows up, I've got another idea, and if that blows up I'll start crying.
When I die, I would like to go peacefully, in my sleep, like my grandfather did. Not screaming and yelling like the passenger in his car.
