Old 08-20-2011, 06:52 PM   #1 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
Dont block the openings on your bmw M1
Found this 'article' interesting. It was in Maxim Sept 2011.
THe 1 series BMW are pretty small. THis was commentinging on the 'M' version. 0-6 in 4.7sec twin torbo straight 6. (maybe from the 330?)
As you might be aware bmw has a moveable grille block on at least the 5 series.
I gues, if your going fast, you want the air going thru the car.
if your ecommodding you want it to go around.
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 08-20-2011, 07:00 PM   #2 (permalink)
mcrews's Avatar
speaking of air going THRU a car.
I have always been amazed at the ducts on the 1966(?) ShelBy GT-40:
And then, the cobra Coupe
ECO MODS PERFORMED:
First, Grille Block
The Following User Says Thank You to mcrews For This Useful Post:
graydonengineering (08-21-2011)
Old 08-21-2011, 07:55 AM   #3 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
Note those ducts are for brake cooling.
In a track car, speed is worthless if you can't slow down enough to make the turn !
Ecomodders use the brake so little, they never get warm.
My vehicles have 135K miles and 168K miles on the factory brakes. Although the Express van is tapping the wear indicators occasionally.
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 08-22-2011, 03:59 AM   #4 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Having the air from the radiator exit through the hood is one of the best solutions from an aerodynamic point of view.
Vekke also had one on his Seat Cordoba.
Lifetime fuel consumption :
