Old 12-04-2009, 10:52 PM   #11 (permalink)
Curious....
koihoshi's Avatar
DoesNotHaveANickname - '99 Escort ZX2
Well, technically speaking, since a carburetor setup is manipulated through a system of jets, vacuum, and manual tuning, it's far more primitive. Fuel injection systems nowadays can be more efficient because the actual amount of fuel can be changed at intervals, rpms, speed, and tons of other variables depending on the ECU. not to mention lots of different injectors can even change the pulses of opening/constant/not constant. So fuel injection is a FAR more efficient system when it comes to making power AND burning fuel. This isn't counting the other variables that go in, such as air flow measurement, air to fuel mixture it can calculate.... all of which carburetor setups are unable to do since the only variables there are jetting, air/fuel mixture, vacuum, and balancing the carbs, which is a static variable except for wear and tear and re-tuning later most the time.
You can spend tons of money on performance carbs though. But stock for stock, fuel injection for the win. This is why a lot of people move over to aftermarket fuel injection systems on some performance vehicles. One such example is old european cars with "CIS" which is a BOSCH Design where it was mechanical fuel injection, and ran off of vacuum and really primitive sensors and vacuum measurement. A lot of people junk that setup and move over to a system called "MEGASQUIRT" which is a Do it Yourself type project where you essentially BUILD a fuel injection system based off of EFI which makes more power, easier to tune, more efficient, better mileage, less weight, yadda yadda....
There's also other variables on HOW it injects it. Since carb mixes everything before it hits the combustion chamber.... fuel injection can also do things such as injecting it before the valves, some injection setups are a direct injection into the combustion chamber itself (VERY efficient, but not seen on many setups). So pick your variables, your budget....
A megasquirt system can be had for about $500 if you're willing to weld, do the legwork, have a laptop, and love tinkering....
Old 12-05-2009, 01:36 PM   #12 (permalink)
are you
Originally Posted by 69chevelle View Post
Which is better fuel injection vs Carburetor for drag racing I guess from a eco perspective?
Are you doing a launch at redline,and then letting the clutch progressively lock up over the 1/8-or 1/4 mile? If so,then would it make a difference?
If the engine is throttling down the course,the "efficiency" of a duel-feed 4-barrel Holley/Edelbrock/Carter carb. might be approached with a multi-throttle-body EFI system,allowing,out-of-the-hole low end response and top end power.
Is that kinda what you're asking?
There are so many applications and possibilities it would be difficult,if not improper to make any general blanket statements.
Old 12-06-2009, 04:33 AM   #13 (permalink)
The Atomic Ass's Avatar
2-Wheeled Mule - '06 Burgman 400
90 day: 84.89 mpg (US)
Max - '01 S-10 LS
90 day: 24.7 mpg (US)
Twin Powa - '05 Ninja 250
90 day: 79.09 mpg (US)
Ransom - '01 Bravada
90 day: 16.39 mpg (US)
Send a message via Skype™ to The Atomic Ass
Originally Posted by MadisonMPG View Post
I accidentally a whole coke bottle. Should I a doctor? y/n
How did you accidentally the whole thing? That thing gets WIDE past the neck...
ASE certified day-dream engineer
I'm making beautiful music's now, hear it and like me on Facebook!
Old 12-06-2009, 01:19 PM   #14 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I've heard of accidently light bulbs and flashlights but not coke bottles...
Old 12-06-2009, 01:26 PM   #15 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Direct Injection is better on all accounts. There. I fixed it.
Really? A whole coke bottle?
Old 12-08-2009, 04:37 PM   #16 (permalink)
From an eco perspective, not drag racing is better...
-soD
The Following User Says Thank You to some_other_dave For This Useful Post:
Cd (12-08-2009)
Old 12-08-2009, 05:23 PM   #17 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
I am 12 and what is this?
Old 12-08-2009, 05:26 PM   #18 (permalink)
Cd
Ultimate Fail
Cd's Avatar
If you want to drag race, yet do it in an environmentally friendly way, look at what this guy is doing :
Welcome to Plasma Boy Racing, home of White Zombie, the world's quickest street legal electric door slammer in the 1/4 mile drag.
Low 11s and has the potential to be zero emissions if recharged using wind / solar power.
I love '69 Chevelles BTW ( minus their pollution )
Old 12-08-2009, 07:02 PM   #19 (permalink)
Steve - '92 Festiva
It's a fish.
CdA list Daox Aerodynamics 106 03-30-2012 06:02 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
Mythbusters tests "golf ball" dimples NeilBlanchard Aerodynamics 33 11-12-2009 09:52 PM
AutoSpeed Article: Low Drag Car Aerodynamics TestDrive Aerodynamics 3 03-10-2009 10:50 AM
aero-mods,installment#9(internal drag) aerohead Aerodynamics 39 07-11-2008 05:45 PM
