Old 07-13-2017, 09:52 AM   #1 (permalink)
JockoT's Avatar
All That Jazz - '06 Honda Jazz i-DSI S
90 day: 48.72 mpg (US)
Traffic lights.
Since starting on the Hypermiling drug I have discovered something about lots of traffic lights here in Scotland. Lights on the main drag are geared to through traffic, and don't change very often for crossing/joining traffic. They have sensors set into the road, within 10 metres of the stop line, and until you make that sensor the light stays on red. Without making the sensor the lights will change, but it can be once every 5-7 minutes, depending on the time of day. It kind of spoils trying to time the lights.
People Think They Are Thinking When They Are Merely Rearranging Their Prejudices
Old 07-14-2017, 12:55 AM   #2 (permalink)
Too many cars
Gasoline Fumes's Avatar
CRXFi - '88 Honda CRX XFi
Insight 256 - '00 Honda Insight
Gen-1 Insights
Insight 5342 (no IMA) - '00 Honda Insight
Gen-1 Insights
90 day: 66.3 mpg (US)
It's not always easy, but the trick is to get someone else in front of you to change the light!
2000 Honda Insight
2000 Honda Insight
2000 Honda Insight
2006 Honda Insight (parts car)
1988 Honda CRXFi
1994 Geo Metro
Old 07-14-2017, 03:01 AM   #3 (permalink)
JockoT's Avatar
That's the problem with these lights. a couple of cars an hour is a busy spell. The good thing is, once you stop in the box the lights start to change, so there is no advantage in switching off. The next set of lights along from those are peculiar. The main drag goes amber, red, then, if there is nothing waiting to come out the side road, goes straight back to red/amber, green. First time I saw it I thought my eyes were playing trick. Green, Red to Green in about 3 seconds!
Old 07-14-2017, 11:56 AM   #4 (permalink)
Renee - '92 Renault 50 Series
90 day: 21.21 mpg (US)
EscortEstate - '97 Ford Escort mk6 ANL
90 day: 37.66 mpg (US)
I have read about bikers fitting magnets to their bikes so that the sensors see them as a car and change sooner. unfortunately fitting a magnet to a car doesn't do much.
Most traffic lights here is sweden work well with this system. At night on a quite road you can just keep driving at normal speeds even if it is red and 9 times out of 10 it will go green just before you need to slam your brakes on (so as not to run through a red light).
Old 07-14-2017, 12:59 PM   #5 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
If you know you're going to stop, you key off well before the stop and glide on in. Bump start when you're pulling into the box, and you're golden- just pull on out with the green.
Transmission type Efficiency
Old 07-14-2017, 01:00 PM   #6 (permalink)
JockoT's Avatar
Originally Posted by MJamson View Post
At night on a quite road you can just keep driving at normal speeds even if it is red and 9 times out of 10 it will go green just before you need to slam your brakes on.
That's a great idea. Lights here don't have sensors as you approach, though temporary lights at roadworks usually have camera on top, so they can see vehicles approaching and change appropriately.
Old 07-15-2017, 12:15 AM   #7 (permalink)
We used to have some at a quarry that I worked at, we discovered that those were IR cameras and that you could encourage them to change by flashing your full beams.
I tried it out on the roads and got mixed results, so it might depend on how they are positioned or it only works on a few particular cameras.
Old 07-15-2017, 04:46 AM   #8 (permalink)
JockoT's Avatar
I found that too. As you approach you stick your full beam on and they see you sooner.
