Old 09-01-2008, 12:45 AM   #1 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
Drawing a line for aerodynamics
something occured to me in the 1980s, early 90s. The first zippy little car I ever drove was an mx6 (a mazda). As it turns out, ALL zippy fwd cars have some easily identifiable association with sumilar aerodynamics, size and shape to this very flunking day.
I felt very confident climbing into the 80s mph on a dirt road...and then it happened. the cars back end floated for at least a mile. I knew not to touch the brakes. the biggest frustration was letting off throttle letting the engine be the brake...and the transverse idiot design fed the float. It is in all cars today. every last fwd ricer..
I drew the line. I would rather a slightly jacked up goofy shape that will tell me way way before sports car attempt that the car is too light to pretend with aerodynaimcs. Weight is the bigger factor, and as it turns out...when you do have weight...noone talks aerodynamics anymore.
Be Careful with your hypermiling aerodynamic pursuits. Obvious flaws may be for the very reason I just spoke. A false sense of confidence is deadly...aerodynamics is one of them.
A four wheel drive in the little car category helps, even in places that don't need it. Imagine if they made it a standard to really acheive instead of cheapskating with life and death...
Old 09-01-2008, 12:51 AM   #2 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
wat
Old 09-01-2008, 01:04 AM   #3 (permalink)
Red
Red's Avatar
Fish - '02 Sebring LXi
Send a message via MSN to Red Send a message via Yahoo to Red
Put the bottle/pipe/joint down dude.......
Old 09-01-2008, 01:18 AM   #4 (permalink)
Humm... You were doing over 80 mph on a dirt road, and you think it was aerodynamics making the rear end float? Sure :-)
Old 02-17-2010, 11:48 AM   #5 (permalink)
Eco Amateur
AeroCav - '03 Cavalier
I drew the line. I would rather a slightly jacked up goofy shape that will tell me way way before sports car attempt that the car is too light to pretend with aerodynaimcs. Weight is the bigger factor, and as it turns out...when you do have weight...noone talks aerodynamics anymore. Be Careful with your hypermiling aerodynamic pursuits. Obvious flaws may be for the very reason I just spoke. A false sense of confidence is deadly...aerodynamics is one of them.
I seem to recalled reading about Bajoos and his AeroCivic... Weight was added. Aerodynmics were the outcome.
Its not the weight. You can add weight and get better FE. You can subtract weight and get better FE. Its the aerodynamics. If I drove a 1970s Mustang, and swapped all the metal with fiberglass... I will only get minimal results. Same thing as if I had a 2001 Lancer. Weight reduction only goes a short distance.
Thats about all I can figure he's talking about. I could be way off.
Old 02-17-2010, 12:30 PM   #6 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
It's in just about every FWD car and has nothing to do with aerodynamics. It's the front to rear weight ratio. FWD cars are usually so light in back that they fishtail easily. Your 80 mph on a dirt road is about the same as driving normally in the snow.
One reason I prefer wagons is they have a little more weight in the back. I also keep some extra weight in back too for better control. One reason I won't drive my Celebrity in winter is it fishtails too easily. My friend noticed the same thing between a Taurus sedan and the equivalent Taurus wagon.
Letting off the throttle to be the brake, same deal. When going down a steep slippery hill, I'll often shift into Neutral so I don't have the front end trying to hold me back and encouraging the rear end to break loose. At least when using the actual brakes to maintain speed, I have 4 wheels slowing me down instead of the 2 front ones.
Winter daily driver, parked most days right now
Summer daily driver
the bottom line, people have be forced to conserve. diesel_john General Efficiency Discussion 57 05-17-2008 11:37 PM
New job starting - less time on line brucepick The Lounge 3 02-21-2008 05:51 AM
Cheap Fix for a Tranny line? WaxyChicken Off-Topic Tech 18 02-14-2008 03:29 AM
91 Geo full line fuel efficient brochure dissimilation For Sale 8 01-26-2008 08:38 PM
