Old 04-18-2016, 01:32 PM   #11 (permalink)
3-Wheeler's Avatar
AlienMobile - '00 Honda Insight
90 day: 80.05 mpg (US)
Caution using just water
Hi,
I have several cautions on using just water in a radiator of an auto.
1) The water boils at a much lower temperature than coolant
2) The coolant has lubricant, depending on water pump design, keeps bearings lubricated.
About 30 years ago, I did an engine flush, and filled the radiator with mostly water. Two months later, the water pump bearing failed!! Ouch.
Jim.
Old 04-18-2016, 08:45 PM   #12 (permalink)
You were lucky if you didn't have at least one head gasket burnt.
Old 04-18-2016, 09:19 PM   #13 (permalink)
Marshmallow - '88 Ford LTD Crown Victoria LX
I used pure water because I didn't wanna spend money on coolant, only to dump it along the road! I reckon it is okay for such a short distance. Currently the car is running fine, it's back to the regular 50/50 of the green stuff and water.
I did a compression test after I got it back. Everything is okay, so I am assuming head gaskets are not burnt up. Fingers crossed.
