Old 06-04-2008, 01:51 PM   #1 (permalink)
SirKeats's Avatar
GeRide - '89 Geo Metro *XFi
90 day: 54.26 mpg (US)
Cruise Control Options for 5spd Metro's
A good portion of my daily commute is on the highway... where I try to maintain a steady speed of 55mph.
Having some way of simply setting a cruise control would be nice. I'm wondering if anyone has rigged anything up and if so how they went about doing so.
Thanks!
Old 06-04-2008, 04:19 PM   #2 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
to add cruise to a 5 speed all thats really diffrent is a secondary cut out switch on the clutch.. However ofter cruise isn't the most effective for getting best MPG.. however keep your foot from getting tired..
I know Jc Whitmey and other autoparts places like that have aftermarkey cruise setups.. usually they consist and a wheel speed sensor and a actuator that hoot to the throttle and then wiring and switchs and the control module and switches you turn it on and off from..
However if your adventurous enough you could do the old school "cruise control" .. like bajoos did on his areocivic.. the hand operated "throttle stop" when put in place it just holds the throttle for you in one position.
Old 06-04-2008, 07:42 PM   #3 (permalink)
SirKeats's Avatar
this is kind of what i was thinking. i remember my grandpa telling me about these setups!! LOL
i'll search for bajoos post on this. thanks!
Old 06-04-2008, 09:31 PM   #4 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
I have an aftermarket cruise in my car - AudioVox? Didn't need the clutch switch, as it monitors the tach signal (coil wire) and shuts off if it detects a sudden RPM rise.
Unfortunately, it's currently on the fritz and I haven't yet investigated why.
The throttle stop would be more efficient - and potentially less safe.
Old 06-05-2008, 11:00 AM   #5 (permalink)
SirKeats's Avatar
i'm having a hell of a time finding the thread covering the throttle stop... can anyone point me in the right direction?
thanks!
Old 06-05-2008, 11:08 AM   #6 (permalink)
Veggiedynamics
thanks!
I don't know if he did a entire thread on it it was in the thread about the areocivic.. he mentioned it and why and then had photo of the setup..
Old 06-05-2008, 11:09 AM   #7 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
There's one in this on-board welder site: http://www.4crawler.com/4x4/CheapTri...er/index.shtml , I've got one in a bin somewhere...
You can shove it closed by pushing on it or turn it to fine tune the throttle setting. Connect it to your throttle with a piece of small chain so your pedal works when this is disengaged.
Cruise Control (with MPG sensitive logic) guitarterry EcoModding Central 224 05-13-2017 11:10 PM
Cruise control hack/modification? ArtFox DIY / How-to 8 07-06-2015 04:00 PM
Aftermarket Cruise Control homeworkhome53 DIY / How-to 19 12-10-2008 07:07 PM
3 ?'s (SuperMID; cruise control for Metro) Pillzilla EcoModding Central 16 03-31-2008 06:34 AM
TP control? Harpo EcoModding Central 9 03-14-2008 06:54 PM
