DRL Kill Switch?
I found a good tutorial online to disable the DRL's on my '01 Cavalier.
http://www.j-body.org/forums/read.ph...8&t=326113&p=1 I'm not that good with electronics so I hope this isn't a stupid idea. If I purchase a switch at Radio Shack, can I wire that so that I can switch the DRL's on and off, instead of doing a permanent off solution? |
gamer_jim -
I just bent a pin on a relay for my car's lights (it's a Saturn-only mod). I keep a spare fuse in my trunk if I want/need to switch it back. CarloSW2 |
I also added a switch on my DRLs, but I DO switch them back on, during the day, in certain types of driving.
Question about what type of switch to use.
I don't know electronics that well so please forgive the ignorance. I read this about switches: http://www.kpsec.freeuk.com/components/switch.htm and from what I understand I need a SPDT, Single Pole Double Throw switch, is that correct? Because I want to either continue the blue wire circuit or switch it to the ground (if you followed the tutorial I linked in my OP). I found this switch at Radio Shack that I really like: http://www.radioshack.com/product/in...entPage=search but it is listed as a SPST. Will this not work for me? I do not like any of the SPST switches listed on RS's website. I'm trying to stay way from the mad-scientist look in my car as this may become my wife's primary car in the future. Recommend any other places to buy or different switches? |
Mine goes off with the parking brake engaged, so I did a "Redneck Fix" and grounded the parking brake wire so the DRL's are off but I will never know if my brakes are gone ;)
That's what I did too, Johnny. Except I put a switch in between the wire & ground. The parking brake light on the dash reminds me the DRLs are out.
You need a switch that has 3 pins per pole. |
