Old 08-12-2008, 05:40 PM   #11 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 civic Hx
Last 3: 58.02 mpg (US)
Si rear discs
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Old 08-12-2008, 09:21 PM   #12 (permalink)
Originally Posted by Vince-HX View Post
Si rear discs
better fade resistance but not less drag
disk brakes will almost always have more drag than drums
Old 08-12-2008, 10:05 PM   #13 (permalink)
Idiot Suv?? Sav?? Sev?? S
metroschultz's Avatar
SuperElasticBubblePlastic - '93 Metro plainjane
90 day: 53.91 mpg (US)
SilverHairBeauty - '01 Avalon XL
90 day: 24.06 mpg (US)
Send a message via AIM to metroschultz
Not true
Newer, 1995 & up, are designed so the "O" ring in the bore actually pulls the pad away from the rotor. If you experience drag with a set of discs, you have other issues that need to be addressed.
Sticking slides,
bad calipers, (rusty inside, or worse)
bad hoses,
master cylinder not releasing,
Or something else entirely.
But
drums can be adjusted for zero drag,
be aware though that your automatic adjuster will bring right back up if it is working well.
just some insight,
S.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
Old 08-12-2008, 10:15 PM   #14 (permalink)
Vince-HX's Avatar
EJ7 - '96 civic Hx
Thats pretty interesting Metroschultz, learn something new everyday.
And based on personal experience with my (RIP) 91 crx si, I had very little drag with the rear discs compared to my properly adjusted rear drums on my 96 civic. I also have a set of discs for the civic but i'm lazy, haha.
So keep the drums, maybe drill some "speed holes" for a bit of weight reduction , and jam the adjuster might be the best answer
www.full-race.com
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 529 03-12-2012 02:16 PM
reducing drum brake drag Gregte DIY / How-to 40 10-19-2011 02:48 PM
Lightweight Brake Rotors and Flywheel Raysp30 Off-Topic Tech 8 08-20-2008 11:51 PM
DIY Needed - adjusting parking brake pull Yaristock DIY / How-to 22 04-17-2008 09:51 AM
Brake Specific Fuel Consumption: A Really Useful Concept tasdrouille General Efficiency Discussion 8 04-11-2008 10:04 PM
