Go Back   EcoModder Forum > Classifieds > For Sale
Old 09-18-2011, 11:54 PM   #1 (permalink)
DSP 3+ Immo Full
Caution: Please don't try to disassemble the machine.No warranty if the machine is disassembled!
Note: Users can purchase any software to expand its function, or add supported car models. Please Click on this link for the software you want: 3503211
Introduction of Data Specialist Plus 3+:
Data Specialist Plus 3+ also called DSP III+, DSP 3+. DSP III+ is the most complete programming device for digital odometers, airbag modules, car radios, car immobilizers. It is a high-quality embeded system, which offers a maximum of flexibility and working comfort.
Technical reference
Data Specialist Plus 3+ power by ARM 10 TDI and CORTEX ARM cores, speeds up to 600MHZ, 800*480 TFT LCD and touch screen(7.0".16:9). Convenient keyset. USB host and USB device. SD card interface. 128MB NandFlash, 128MB SDRAM.
Self-check function integrated in system.
Enhanced OBD functions, including CAN-BUS / J1850 / CCD-BUS / ISO9141 / SPI protocols.
Intuitive operability by full menu and picture guidance. All data can be edited, stored and loaded.
Color connection picture is on the screen whenever you need.
The stored data can be transferred to a PC by USB port or SD card, and also can be transfer to wherever you want directly by internet.
Update directly from internet.
Immo full package (include all software and hardware)
Data Specialist Plus 3+ Immo full package: DSP III+ main hardware, Transponder adapter, OBD cables, USB cable, Power cables, with full soft.Software: OBD functions for Immo are all active.
Ford / Mazda: Key learning by OBD2 (not need code) for CAN-BUS cars.
4th Generation of VW Immo:
1. Make dealer keys by Megamos48 chip (using transponder adapter).
2. Key learning by OBD2 (not need code , not need online).
3. Cover all VW / SKADA / SEAT cars that use NEC or Micronas or 9s12xhz512(1M80F) MCU in dashboard.
4th Generation of AUDI Immo:
1. A6 / Q7
2. A3 / TT / R8 07-UP
