Old 04-17-2008, 01:28 PM   #21 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
Originally Posted by apgrok1 View Post
Ok we know all of the things that can go wrong, but we still don't know why it is there. I know that GM Quad 4's had cold start emmision problems, I am assuming this could also apply to the volvo's. The hot air intake would help emmisions in that case.
? See a few posts up....
The air flap mechanism in the volvo airbox works to maintain a minimum 70f intake temp in order to make the AMM readings more accurate.
Challenge me, or correct me, but don't ask me to die quietly.
Old 04-17-2008, 09:43 PM   #22 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Not sure what the question is
I owned a car with that miserable engine ('90 Beretta GTZ). The biggest emission problem was the coolant going out the tailpipe (head gasket issues).
The engine had great potential: a DOHC, 16V, high-compression, lightweight domestic engine that cranked out 180 hp from 2.3L. 5-Speed -- fun car. 75K miles it started acting funny. White vapor from the tailpipe and chocolate brown coolant. Cold starts sounded like the cylinders rings were grinding for the first few seconds. This is when I gave up and bought my first Civic.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 04-17-2008, 10:41 PM   #23 (permalink)
MechE
RH77
Sorry for the random "?" -- apgrok asked why it was there - but tjts1 had already given a pretty thorough explanation as to the way (not trying to be an ass - just keeping info moving)
Old 04-17-2008, 11:02 PM   #24 (permalink)
RH77's Avatar
Just bustin' chops, as is my duty.
RH77
EF5 / 22-May-2011
_
_
Old 04-18-2008, 09:24 AM   #25 (permalink)
What I meant was that the hot air device was there for emmisions, not just to heat the engine sooner, although the two go hand in hand.
BTW, I also owned a 2.3L Quad 4 and also replaced a head gasket.
Old 11-04-2008, 04:57 AM   #26 (permalink)
EcoModding Minded
Chris D.'s Avatar
Lunar Mist - '02 Tacoma SR5
90 day: 25.31 mpg (US)
Silver Streak - '08 Corolla S
90 day: 38.25 mpg (US)
Send a message via AIM to Chris D.
ok, I've bumped this thread in hopes of seeing
someone running a retrofitted setup on their ride..
So has anyone gotten fiesty and tinkered with this?
the selectable HAI/CAI setup is going to be my next mod..
Old 11-04-2008, 12:33 PM   #27 (permalink)
B2300 - '96 B2300 SE
Big Red - '88 Concours ZG1000
90 day: 54.41 mpg (US)
Zongshen Sierra 200 - '06 Sierra 200 Supermoto
90 day: 82.11 mpg (US)
Have not done it but have some info.
Many old carbureted (and early EFI ) vehicles have a vacuum acutated heated intake that regulates temp at about 100*F. These have a bimetallic strip valve mounted on the clean side of the air cleaner. There is a vacuum diaphram controlled by the strip that regulates hot air from the exhaust manifold and cooler air from outside. The bimetallic strip bends at a certain temp and bleeds vacuum air to the diaphram thereby regulating the intake air temp. These are really simple devices and in my experince very reliable too. Sorry, don't have a diagram available.
The beauty of this is that at low vacuum (wide open throttle) the vacuum is not enough to pull the diaphram to feed warm air, so full cold air is fed when most needed for power. When vacuum is restored at partial throttle it's back to 100*F air. Best of all, the exposed versions of the bi-metallic strips are actually tuneable so you can play with the regulated intake temp that suits your engine, within a certain range of course.
The two vehicles I had that had this were: '72 Datsun 510, '95 Dodge Caravan, but they were also widespread on other vehicles from the early 70's to late 80's. If you see a vacuum diaphram on the air snorkel of a suspect vehicle, you've found one of these systems.
Learn and Share your driving and modding skills at the MPG Challenge in Lacey, WA. First Saturday in May!
http://www.ci.lacey.wa.us/city-gover...ve-energy-fair
5th generation civic hatchback - improving aerodynamics AndrewJ Aerodynamics 383 05-15-2012 08:40 PM
Intake manifold heater Bearleener EcoModding Central 2 03-18-2008 02:43 PM
What does this part do? Green Machine EcoModding Central 10 02-18-2008 12:57 AM
[Product Review] Nashbar Dual Cyclocomputer SVOboy Alternative Transportation 0 12-07-2007 12:03 AM
Trying out an aftermarket Intake on a VX TomO EcoModding Central 0 11-14-2007 03:41 PM
