Old 07-19-2011, 06:50 PM   #1 (permalink)
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 46.69 mpg (US)
Big Red - '00 Excursion XLT
90 day: 15.53 mpg (US)
Ducted Radiator
For years I've been driving around with my grill 100% blocked. I finally got tired of replacing radiator fans because of it constantly turning on and off so, I cut a hole in my grill block. My transmission cooler was not very effective either, so I upsized it also. I used some coroplast "surplus" signs to make my ducting. It is just jamed in there. I made the duct as wide as the trans cooler and radiator even though the grill block hole is much smaller, just as wide as the licensce plate, just in case I want to block it again.
The results are great. The fan has only turned on in stop and go traffic and the temps stay under 210 on the highway. The trans temp is way lower because it now has significant air flow and a three times larger cooler. On the down side, it takes waaaay longer to warm up. It would be nice to have an on the fly grill block.
It seems like it has helped the instant mpg numbers slightly, but if it did help, it is very small.
Old 07-19-2011, 06:57 PM   #2 (permalink)
Location: Live in Tucson AZ, work and car now in Detroit
Protege - '97 Protege DX
90 day: 42.23 mpg (US)
You said "ducted" that got me thinking... How about a furnace vent used on forced air furnace in a home (12x8 inches, couldn't be more then $10 dollars at Home Depot) They have levers on them to open and close. Run a cable next to the hood release cable then you can open/close the vent from the drivers seat.
Old 07-19-2011, 07:57 PM   #3 (permalink)
graydonengineering's Avatar
Frontier 2wd 2.4L 5 speed - '98 Frontier XE
90 day: 27.72 mpg (US)
Yes, only problem is, the luvers will give a fair amount of restriction requireing a larger opening for the same cooling effect. That would be a fast simple solution though.
You could also make a single paddle on a horizontal shaft actuatated by a cable exactly like a throttle body. When in the horizontal "wide open" position, it would cause very little restriction.
-Miles
Best 15-mile commute city/highway mix: 37.7 mpg
Best tank so far: 31 mpg
Old 07-22-2011, 05:56 PM   #4 (permalink)
Team ZX2
It was around 107 today with 60% Humidity. The Duct worked great. I'd say it performs as well as not having grill block at all! The fan never kicked on while on the highway and kept temps around 215, which is just right
Old 07-22-2011, 08:47 PM   #5 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
take a look at my lower grill block page, I have used two forced air grates to block and remotely open the lower grill.
