Let me rephrase the question: why wouldn't you also want less drag in the racing engine? Why limit the mod to the qualifying engine? If it helps in qualifying, won't it also help in racing?
I have to put rings in the motor I got from Coyote.
I may go ahead and order Xfi pistons and ring set when I get started doing the work.
I have found it to be in my best interest to do pistons with rings during a tear down. Got burned once by a cracked ring groove and it left a bitter (and expensive ) taste in my mouth.
I'll keep you posted.
S.
You can turn painful situations around through laughter. If you can find humor in anything - even poverty - you can survive it. Bill Cosby
Reason: spelling
